Results 1 to 5 of 5
Thread: Methods of Hydraulic Fracturing
  1. Methods of Hydraulic Fracturing
    Hello
    I have questions about Hydraulic Fracturing, which follows:
    1. Please Mention the name of Hydraulic Fracturing Methods ( Just Names )
    2.which one the methods is more efficient in Gas reservoirs(Makes Wider Fractures) !? and which one is more efficient in Oil reservoirs ?!
    i will be appreciated by answering the questions, i am looking hearing from You
    best regards,
    farzadt
    Re: Methods of Hydraulic Fracturing
    what are the softwares of Hydraulic Fracturing?
  5. Re: Methods of Hydraulic Fracturing
    Quote Originally Posted by farzadt View Post
    Hello
    best regards,
    farzadt
    From the top of my head: hydraulic fracturing is when you inject fluid downhole and pressurize the wellbore such that the fluid is not able to leak off fast enough and rock -----s eventually.
    When you say "methods" what do you mean? There are different types of fluids (water-based, oil-based), different placement techniques (through Coiled tubing, by means of jetting tools, conventional hydraulic fracturing through tubing and packer, acid fracturing, etc.
    Also, there are some techiques when you try to control the proppant settling while pumping and attempt to generate desired fracture geometry: e.g. "proppant bridging at the bottom of the fracture and prevent growth downwards to water").
    Regarding fracture width, it is generally accepted that low permeability formations need less wider fracture. However fracture in low-perm formation should have extensive length and safe height to provide reasonable inflow of hydrocarbon fluid (be economically viable).
    Therefore, if the formation has high permeability (>30mD???) it needs short but wide fractures. Fracture conductivity should be sufficient to transmit flow from fracture surface to the wellbore.
    If you need more information, seek for Michael J.Economides books.
  6. Re: Methods of Hydraulic Fracturing
    Quote Originally Posted by bendorf View Post
    Halliburton: FracPro PT
    Schlumberger: FracCADE
    Trican: M-frac
    and a lot more
  7. Re: Methods of Hydraulic Fracturing
    thank you for sharing information with us, thank a lot,
    additionally thank you for Softwares you name for Us
  1. Hydraulic fracturing
    By rossylea512 in forum Drilling And Workover
    Last Post: 09-10-2013, 01:43 PM
  2. shale gas and hydraulic fracturing
    By Antoshka in forum Safety And Environment
    Last Post: 05-28-2013, 06:58 AM
  3. hydraulic fracturing job
    By mohammed105 in forum Oil And Gas Production
    Last Post: 03-28-2013, 10:17 PM
  4. Article: Re: Methods of Hydraulic Fracturing
    By ropHocTau in forum Home Articles
    Last Post: 07-14-2012, 01:14 AM
