Thread: Co2 freezing point with Prode Properties
    I am calculating Co2 (in natural gas) freezing point with Prode Properties,
    according your experience which is the correct option as thermo package ?
    Peng Robinson and Soave Redlich Kwong packages give quite equivalent results.
    Thank you.
    Re: Co2 freezing point with Prode Properties
    with the vapor-solid equilibria flash available in Prode Properties I have tested methane-Co2 and some other mixtures with Soave Redlich Kwong and SSM package available in Prode Properties,
    errors for freezing point temperatures are in a range from 1 to 5 C compared with experimental data,
    I have not verified Peng Robinson but I presume it gives equivalent accuracy (I may be wrong)
  1. Prode Properties in VB NET
    By hans23 in forum Engineering Programming
    Last Post: 09-30-2011, 07:25 PM
