Results 1 to 8 of 8
Thread: ASME B31G calculation
    Good afternoon to all.
    I will join a new pipeline inspection company in France to manage the inspection pig operations. Then I start to check the best wy to calculate a failure pressure considering a corrosion feature. Then I choose the simpliest way and bought the ASME B31G version 2009 which is tha latest update. I've been surprised by the document because I use it in the past and in the past it was possiblle to calculate the maximum alowable length using the vallue B which could be calculate or just take from a curve.
    Does somebody can telle me if it is ever possible to use this calcuation length or not and my second question will be considering the curve ERF=1 which as to be create to place defects on it. Does somebody could explain me how to trace this curve?
    Best regards
  3. Re: ASME B31G calculation
    Please see ASME B31G-2009
    Greetings
    Abo Khaled
    Attached Files Attached Files
    Thank you
    Thank you
    Muchas Gracias Abo Khaled
    Nov 2012
    Sogamoso,Colombia
    please review the standart
    Aug 2011
    Pune, India
    Thanks Dear,
    Best Regards,
    Amit
    This code was update..last year (2012) was created a new.
  1. ASME B31G-Spreadsheet
    By Bombini in forum Engineering Spreadsheets & Presentations
    Last Post: 01-30-2019, 06:06 AM
  2. ASME B31G-Spreadsheet
    By Bombini in forum Materials Science &Corrosion
    Last Post: 02-28-2017, 01:45 AM
  3. Asme b31g
    By madmax in forum Pipeline And Fluid Flow
    Last Post: 03-28-2014, 09:20 AM
  4. Asme B31G 2012
    By Octavio in forum Pipeline And Fluid Flow
    Last Post: 09-06-2013, 06:22 PM
  5. ASME B31G and B31.8S 2012
    By codigo98ii in forum Pipeline And Fluid Flow
    Last Post: 09-02-2013, 06:16 PM
