Thread: ISO Standard 14644
    ISO Standard 14644
    Dear collegues of forum,
    I'm looking for the following standard:
    Clean Rooms - ISO Standard 14644
    Could you help me?
    Superandy
    Re: ISO Standard 14644
    AS/NZS 14644
    Cleanrooms and associated controlled
    environments
    Part 1: Classification and air cleanliness
    Part 2: Specifications for testing and monitoring to prove continued compliance with ISO 14644-1 (ISO 14644-2:2000, MOD)
    Part 4: Design, construction and start-up
    Part 5: Operations
    Part 7: Separative devices (clean air hoods, gloveboxes, isolators and minienvironments)
    htxx://www.mediafire.com/?9h6ud7el17e55dj
    BS EN ISO 14644
    BS 5295-0 1989.pdf
    BS EN ISO 14644-1 1999.pdf
    BS EN ISO 14644-2 2000.PDF
    BS EN ISO 14644-3 2005.pdf
    BS EN ISO 14644-4 2001.pdf
    BS EN ISO 14644-5 2004.pdf
    BS EN ISO 14644-7 2004.pdf
    BS EN ISO 14698-2 2003.pdf
    htxx://www.mediafire.com/?5av3ubf7de03vrt
    Pass: Tieuchuanbs@gmail.com
    Thanks, had to use a different program to open it.
    File is Good
    Thank Tranquang !
  1. standard
    By maksimilijan in forum Safety And Environment
    Last Post: 08-17-2011, 08:44 AM
  2. Ped standard
    By tobbe in forum Pipeline And Fluid Flow
    Last Post: 07-27-2011, 11:54 AM
  3. Need the following IS Standard (indian standard) urgently
    By SA_FETY in forum Safety And Environment
    Last Post: 07-06-2011, 09:02 AM
  4. api standard
    By hosain yasi in forum Oil And Gas Process
    Last Post: 12-17-2009, 05:23 PM
  5. Jis standard piping standard
    By muthukarthi in forum Mechanical Engineering
    Last Post: 12-10-2009, 03:19 AM
