Results 1 to 10 of 10
Thread: Tank Cooling Water Spray Application Rates
    Question Tank Cooling Water Spray Application Rates
    Hi to everyone,
    I was wondering which standards are used in other Oil Tank Farms about Tank Cooling Water Spray Application Rates.
    1) For API 2030 (American Petroleum Institute) (August 1998)
    7.2.1 Exposure Protection:
    In general , suggested application rates are between 0.10 and 0.25 gpm/ft2 (4.1 and 10.2 lpm/m2) These suggested rates are experience-based and include a safety factor of 0.05 gpm/ft2 (2.0 lpm/m2)
    2) For IP Part 19 (Model Code of Safe Practice Part 19: Fire precautions at petroleum refineries and bulk storage installations) (2nd edition - January 2007)
    Annex D Typical Application Rates
    Table D.1: Minimum application rates for water based systems
    Fixed [Note 3] and floating roof [Note 4] tanks containing Classes I, II and III liquids Application rate: 2 lpm/m2)
    3) What about NFPA Standards?
    4) Which design ojectives / standards are you using in your Oil Tank Farms for Cooling Water Spray Application Rates?
  3. Re: Tank Cooling Water Spray Application Rates
    NFPA15 suggests 4.1 lpm/m2 too.
  5. Re: Tank Cooling Water Spray Application Rates
    Quote Originally Posted by pelin View Post
    In absence of heat radiation calculations from Fire Risk Analysis, we recommend a minimum specific cooling flowrate of 36 l/min per linear metre of circumference, both for floating roof tank and fixed roof tank, indifferently from the product contained, and height of the tank.
    is it 36 l/min or 3.6 l/Min. Please calrify.
  7. Re: Tank Cooling Water Spray Application Rates
    Quote Originally Posted by rkgupta View Post
    I wrote what exactly is written: 36 l/min per linear metre (of circumference).
  9. Re: Tank Cooling Water Spray Application Rates
    NFPA said 4,1 lpm for minimum requirement, for oil tanks watersprinkler it recommended to use ring system because deluge system is not subjected to tank cooling. I've made watersprinkler design and calculation based on API 2030 maybe you interest?
  10. Re: Tank Cooling Water Spray Application Rates
    yes please do send.
    I have posted another thread in the mechanical section but never received a reply. I would appreciated if you could send me your workings.
    See my post:
    Adam
  11. Re: Tank Cooling Water Spray Application Rates
    yes please do send.
    See my post:
    Adam
  12. Re: Tank Cooling Water Spray Application Rates
    Quote Originally Posted by adamjin View Post
    yes please do send.
    See my post:
    Adam
    What is your email, I'd rather sent by mail
  13. Re: Tank Cooling Water Spray Application Rates
    sent a private message
  1. Replies: 3
    Last Post: 04-07-2014, 05:55 PM
  2. Article: Tank Cooling Water Spray Application Rates
    By pelin in forum Home Articles
    Last Post: 06-04-2013, 09:29 AM
  3. cooling system for gasoline tank
    By eng fir in forum Mechanical Engineering
    Last Post: 02-01-2013, 02:46 PM
  4. Any Recommendations on Water Spray of a Vessel
    By jdhariwal in forum Safety And Environment
    Last Post: 04-04-2012, 01:50 PM
  5. Article: Any Recommendations on Water Spray of a Vessel
    By jdhariwal in forum Home Articles
    Last Post: 04-03-2012, 12:32 AM
