Molecular Structure
A second, more complicated way to classify hydrocarbon compounds is by their molecular structure, the actual arrangement of the carbon and hydrogen atoms.
These atoms can combine in a number of ways to satisfy valence requirements. For convenience, these are separated into "families" or homologous series, each of which is given a name.
Every atom has the capacity to combine with a given number of other atoms; this is its valence number. The valence of hydrogen, for instance, is 1. One way of looking at that is to say it has a “hand” that can join with a “hand” from another atom to from a valance bond. Carbon has valence of 4 which means that each carbon atom can combine with four other atoms.
The carbon atoms can link together to form "chains" or "rings." Crude oil and natural gas mixtures consist primarily of "straight chain" hydrocarbon molecules, the bulk of which are paraffins.1.1.2.2 Paraffin Series Formula: CnH2n + 2Paraffins, also called alkanes, were named when early chemists through these compounds were relatively inactive (see Appendix A.2-1).Hydrocarbons in this series are saturated compounds - all four carbon bonds are connected either to another carbon atom or a hydrogen atom, with one such atom for each bond.
Notice that, all names end in -ane, the ending used for the paraffin series. In each case, the number of hydrogen atoms is two times the number of carbon atoms plus two more for the ends of the chain.The paraffin hydrocarbons are the most stable of the lot because all valence bonds are fully satisfied as indicated by the single line linkage. Most reactions involve the replacement of hydrogen atoms with other atoms; the carbon linkage remains stable.Each successive molecule in the paraffin series is created by adding a carbon and two hydrogens to the previous molecule. The incremental change in relative molecular weight is thus fourteen. Long chains con-taining scores of carbon atoms in series may be formed. However, the only ones normally identified by name contain ten or less carbons.
Table 1.1 Common Hydrocarbons M.W
In referring to a given paraffin hydrocarbon, the abbreviation C3 for propane, C4 for butane, etc. may be used. Statements like "propanes plus fraction (C3+)" refer to a mixture composed of propane and larger atoms.Paraffin isomers: When the paraffin series molecule contains four or more carbon atoms there are different ways these can be connected without affecting the formula. Compounds which have the same chemical formula but a different atomic structure are called isomers. They possess different physical and chemical properties.There are only two isomers of butane. In the structural diagram shown below for i-butane we could draw the carbon atom below instead of above the carbon chain. But, this would be just a "mirror image" of the molecule as drawn. It is the same molecule with the same properties. The adjective "normal" is used to designate a molecule wherein all of the carbon atoms are in a straight line. An "isomer" has the same formula but a different arrangement of the carbon atoms. In an analysis, these are often abbreviated as "n" and "i" respectively.(n- C4H10) (i- C4H10)Even though these two compounds consist of the same number of carbon and hydrogen atoms they differ chemically and have different boiling points, densities, and refractive indices. Most important from our point of view is that the simple, straight chain paraffin has a much lower octane than the more compact, branched isoparaffins.As the carbon number increases, the number of possible permutations (isoparaffins) increases astronomically. There are three combinations for pentanes (C5H12), (normal pentane) and two isopentane (called, by convention, isopentane and neopentane).
Similarly, there are 9 possible combinations for the C7 paraffin, heptanes, 355 for C12 and 62, 491, 178, 805, 132 combinations for C40.
An important thing to remember is that no matter how complicated or how simple, all Paraffins have the same ratio of two hydrogen atoms for every carbon atom, plus two more hydrogen, one at each end of the chain to fill the remaining valences.
Chemists express this as CnH2n+2, the formula for all Paraffins shown at the beginning of this section. If we have a two carbon atom paraffin, then n=2, thus there will be 2 x 2 + 2 = 6 atoms of hydrogen. C2H6 is, of course, ethane. You might try going back and checking one or two of the other Paraffins diagrammed above against the formula.
A final point to remember is that the valence bonds of Paraffins are saturated with hydrogen. That is, every carbon atom is holding as much hydrogen as it can; every valence not needed to link it to another carbon atom is linked to a hydrogen atom.
