Dear friends
I need the calculation formula to calculate the(flow rate value and the volume of nitrogen required to purge
1-Storage tanks
2- Pipelines
thanks for you help
Dear friends
1-Storage tanks
2- Pipelines
thanks for you help
yes, pl enlight anyone
Just get into WELD SPECIALTY SUPPLY CORP. You will see their xlspread sheet there. Send me mail address if you do not get it. I send the file. I am unable to attach here.
You will find it here.
Just cut & paste, you will have the spreadsheet .
Downloaded.![]()
Hi Mr ARMOFI
Thank you very much for you sheet for the Nitrogen calculation.
I'm a student and I would like to know what kind of the book or reference you generally use to determinate elemental composition of oil trought correlation. (%C, %H, %S, %O2, %N2, %Metals (Ni, V, Fe)
Generallay I used several correlation of Riazi.
(Riazi, M. R. (2005). Characterization and Properties of Petroleum Fractions. West Conshohocken, Panjeshahi, M. H.).
However this one have several errors and the critical thing I don't found well correlation to N2, O2 and Metals.
So for this reason I need you help. Could you bring me some kind of information about the determination of this elemental composition. You sheet it's already program and I could see the correlation employed for the case of N2.
Another addiotal question that I will like to know it is the table of regulation of elemetal composition to be transport a oil.
What kind of request or law it is necessary to supply for trasport a oil (e.x. %S, %N2, etc)
Finally my mail is: jpl860@gmail.com
Thank so much
Hi,
As far as using of Nitrogen for purging concerned, it depends on the removable of flammable gases inside the pipeline/tank/conduits etc (confined vessel). Particularly , this means Oxygen to a level of 10-12% desirable, the LFL of the content. The level of purging by N2 is dictated by the Client here.(what % oxygen removal required).
Other question I am unable to understand & I think I am not an expert in it. If it is regarding selection of material for oil/liquid transportation, we follow the regulation list 49 CFR Part 192, AppxB. or the selection of materials as per ASME 31.4 / 31.8 or AISI/SAE Classification of metal. Obviously these are API 5L pipes of different schedule & grades.
thanks for this spreadsheet very useful
Thanks for info.
The file can not be found. Please upload again. Thanks.
thanx
very uselful
thanx
very uselful
