P&ID shows all of piping including the physical sequence of branches, reducers, valves, equipment, instrumentation and control interlocks.
The P&ID are used to operate the process system.
A P&ID should include:
  • Instrumentation and designations
  • Mechanical equipment with names and numbers
  • All valves and their identifications
  • Process piping, sizes and identification
  • Miscellaneous - vents, drains, special fittings, sampling lines, reducers, increasers and swagers
  • Permanent start-up and flush lines
  • Flow directions
  • Interconnections references
  • Control inputs and outputs, interlocks
  • Interfaces for class changes
  • Seismic category
  • Quality level
  • Annunciation inputs
  • Computer control system input
  • Vendor and contractor interfaces
  • Identification of components and subsystems delivered by others
  • Intended physical sequence of the equipment
This figure depict a very small and simplified P&ID:
A P&ID should not include:
  • Instrument root valves
  • control relays
  • manual switches
  • equipment rating or capacity
  • primary instrument tubing and valves
  • pressure temperature and flow data
  • elbow, tees and similar standard fittings
  • extensive explanatory notes
