Example - ISA symbols for a Level Indicator
Process Variable Symbol Type of Instrument Symbol Analyses A Alarm A Burner B Users Choice B Combustion B Controller C Users Choice C Control valve CV Users Choice D Trap CV Voltage V Sensor (primary element) E Flow Rate F Rupture disc E Users Choice G Sight or gage glass G Current (electric) I Monitor G Power J Indicator I Time K Control Station K Level L Light (pilot/operation) L Users Choice M Users Choice N Users Choice N Flow Resistance Orifice O Users Choice O Test point (sample point) P Pressure / Vacuum P Recorder R Radiation R Switch S Speed (or Frequency) S Transmitter T Temperature T Multifunction U Multivariable U Valve/Damper V Vibration V Well W Weight (force) W Unclassified X Unclassified X Relay Y Event Y Driver Z Position, dimension Z Actuator Z
A level indicator will receive the symbol "L" for the process variable "Level", and "I" for the "Indicator" type of instrument. Both combines to:
LI
For unique identification it is common to add a number to the ISA code, by example the code for level indicator no. eight may be:
LI 08
