Results 1 to 11 of 11
Thread: ASTM D1142 needed!!
  1. ASTM D1142 needed!!
    Hi,
    I´m just needing the ASTM D1142 : Standard Test Method for Water Vapor Content of Gaseous Fuels by Measurement of Dew-Point Temperature
    I´m just trying to compare resuts with ISO 18453.
    Thanks in advance.
    Re: ASTM D1142 needed!!
    D 1142-95 R00 Standard Test Method for Water Vapor Content of Gaseous Fuels by Measurement of Dew-Point Temperature.pdf 0.103 MB
  5. Re: ASTM D1142 needed!!
    Thanks for your quick response Nabilia!!
    Hi,
    can you please reload the file. The link provided says that the file is not available.
    Thanks in advance.
  7. ÑÏ: ASTM D1142 needed!!
    ÇáÑÌÇÁ ÅÚÇÏÉ ÊÍãíá ÇáãáÝ .. Ýåæ ÛíÑ ãæÌæÏ
  9. Re: ASTM D1142 needed!!
    ASTM New Documents ....
    Document Number Date Title
    can somebody send me D-1142 please to: samouss00@htmail.fr, need it urgently
    thanks !
    Hi guys,
    can somebody send me D-1142 please to: samouss00@hotmail.fr
    I need it urgently
    thanks !
  12. Re: ASTM D1142 needed!!
    Hi Nabilia
    Would you be able to send the link for the ASTM D1142-95 (Rev 2012)?
    Thanks, WS
    The R does not stand for "revision", it means reapproved. If you have the 1995 issue, you have the latest.
  14. #11
    D1142-95(2012) Standard Test Method for Water Vapor Content of Gaseous Fuels by Measurement of Dew-Point Temperature
  1. (Req) ASTM E10, ASTM E94, ASTM E140, ASTM E165, ASTM E709, EN 473
    By prasetyohse in forum Materials Science &Corrosion
    Last Post: 07-11-2019, 06:48 AM
  2. Replies: 13
  3. ASTM A262, ASTM G108 ASTM A923 are required
    By mohammed21 in forum Mechanical Engineering
    Last Post: 12-13-2014, 07:21 AM
  4. Replies: 2
    Last Post: 04-21-2013, 10:30 AM
  5. ASTM D5064 , ASTM D1730, ASTM D1731, ASTM D1732 are required!
    Last Post: 07-30-2012, 05:04 AM
