[h=Actual Head Rise of a Pump or Fan]3[/h] Using the Energy Equation the head rise through a pump or fan can be expressed as:
ha = (p2 - p1) / γ + h2 - h1 + (v22 - v12) / 2 g (1)
where
ha = actual head rise
p = pressure
h = elevation height
γ = ρ g = specific weight
v = velocity
g = acceleration of gravity
The actual head rise can be expressed as:
ha = hshaft - hloss (2)
where
hshaft = shaft work in the pump or fan
hloss = head loss through the pump or fan
The head loss - hloss - through a pump or fan is related to the
- skin friction in the blade passages and is proportional with volume flow - q2.
- flow separation
- impeller blade casing clearance flows
- other three dimensional flow effects
[h=Actual Head Rise for an Inline Pump]3[/h] For a very common installation - the inline pump or fan - where the inlet velocity and the outlet velocity are the same (v2 = v1), and the inlet and outlet elevation are the same (h2 = h1), the generic equation (1) can be modified to:
ha = (p2 - p1) / γ (3)
[h=Specific Work]3[/h] By multiplying (3) with acceleration of gravity - g -, specific work - w - of the pump or fan may be calculated:
w = ha g (4)
where
w = specific work
[h=Example - Head Rise of an Inline Pump]3[/h] An inline water pump works between the pressure 1 bar (1 105 N/m2) and 10 bar (10 105 N/m2). Density of water is 1000 kg/m3. The actual water head (water column) can be calculated using (3):
hwater = (p2 - p1) / γ
= (p2 - p1) / ρ g
= ((10 105 N/m2) - (1 105 N/m2)) / (1000 kg/m3) (9.81 m/s2)
= 91.7 m - water column
[h=Example - Head Rise of an Fan]3[/h] An inline fan working with hot air with density ρ = 1,06 kg/m3 add a pressure of 400 Pa (N/m2) to the flow.
The air head (air column) can be calculated with (3):
hair = (p2 - p1) / ρ g
= (400 N/m2) / (1.06 kg/m3) (9.81 m/s2)
= 38.5 m - air column
The water head (water column) can be calculated with (3) using the density of water:
hwater = (p2 - p1) / ρ g
= (400 N/m2) / (1000 kg/m3) (9.81 m/s2)
= 0.041 m
= 41 mm - water column
Measuring pressure with water column in an U-tube manometer is common in air distribution applications as ventilation and air condition systems.
