The pressure indicates the normal force per unit area at a given point acting on a given plane. Since there is no shearing stresses present in a fluid at rest - the pressure in a fluid is independent of direction.
For fluids - liquids or gases - at rest the pressure gradient in the vertical direction depends only on the specific weight of the fluid.
How pressure changes with elevation can be expressed as
dp = - γ dz (1)
where
dp = change in pressure
dz = change in height
γ = specific weight
The pressure gradient in vertical direction is negative - the pressure decrease upwards.
[h=Specific Weight]3[/h] Specific Weight can be expressed as:
γ = ρ g (2)
where
γ = specific weight
g = acceleration of gravity
In general the specific weight - γ - is constant for fluids. For gases the specific weight - γ - varies with the elevation.
[h=Static Pressure in a Fluid]3[/h] For a incompressible fluid - as a liquid - the pressure difference between two elevations can be expressed as:
p2 - p1 = - γ (z2 - z1) (3)
where
p2 = pressure at level 2
p1 = pressure at level 1
z2 = level 2
z1 = level 1
(3) can be transformed to:
p1 - p2 = γ (z2 - z1) (4)
or
p1 - p2 = γ h (5)
where
h = z2 - z1 difference in elevation - the dept down from location z2.
or
p1 = γ h + p2 (6)
[h=Example - Pressure in a Fluid]4[/h] The absoute pressure at water depth of 10 m can be calulated as:
p1 = γ h + p2
= (1000 kg/m3) (9.81 m/s2) (10 m)
+ (101.3 kPa)
= (98100 kg/ms2 or Pa) + (101300 Pa)
= 199.4 kPa
where
ρ = 1000 kg/m3
g = 9.81 m/s2
p2 = pressure at surface level = atmospheric pressure = 101.3 kPa
The gauge pressure can be calulated setting p2 = 0
p1 = γ h + p2
= 98.1 kPa
[h=The Pressure Head]3[/h] (6) can be transformed to:
h = (p2 - p1) / γ (6)
h express the pressure head - the height of a column of fluid of specific weight - γ - required to give a pressure difference of (p2 - p1).
[h=Example - Pressure Head]4[/h] A pressure difference of 5 psi (lbf/in2) is equivalent to
(5 lbf/in2) (12 in/ft) (12 in/ft) / (62.4 lb/ft3)
= 11.6 ft of water
(5 lbf/in2) (12 in/ft) (12 in/ft) / (847 lb/ft3)
= 0.85 ft of mercury
when specific weight of water is 62.4 (lb/ft3) and specific weight of mercury is 847 (lb/ft3).
Heads at different velocities are indicated in the table below:
Velocity
(ft/sec) |
Head Water
(ft) |
| 0.5 |
0.004 |
| 1.0 |
0.016 |
| 1.5 |
0035 |
| 2.0 |
0.062 |
| 2.5 |
0.097 |
| 3.0 |
0.140 |
| 3.5 |
0.190 |
| 4.0 |
0.248 |
| 4.5 |
0.314 |
| 5.0 |
0.389 |
| 5.5 |
0.470 |
| 6.0 |
0.560 |
| 6.5 |
0.657 |
| 7.0 |
0.762 |
| 7.5 |
0.875 |
| 8.0 |
0.995 |
| 8.5 |
1.123 |
| 9.0 |
1.259 |
| 9.5 |
1.403 |
| 10.0 |
1.555 |
| 11.0 |
1.881 |
| 12.0 |
2.239 |
| 13.0 |
2.627 |
| 14.0 |
3.047 |
| 15.0 |
3.498 |
| 16.0 |
3.980 |
| 17.0 |
4.493 |
| 18.0 |
5.037 |
| 19.0 |
5.613 |
| 20.0 |
6.219 |
| 21.0 |
6.856 |
| 22.0 |
7.525 |
- 1 ft (foot) = 0.3048 m = 12 in = 0.3333 yd
