A reciprocating compressor has a safety valve at its discharge, set at 140 Kg/cm2. There is also an automatic vent control system and a 2 out of 3 high pressure shutdown of compressor. The safety valve is passing frequently and plant management want to install an isolation valve (full bore opening) upstream of the safety valve so that it can take it out for maintenance when the compressor is running.
Can anyone explain the codes that permit an isolation valve to be installed upstream of a safety valve? Is LOPA and SIL analysis mandatory for this case?
