Purpose: To activate the sprinkler system automatically at a particular external temperature.
Working:At the heart of all modern Fire Sprinklers is a heat-sensitive glass bulb. The bulb is filled with a glycerin based liquid dyed different colors depending on temperature and sealed leaving one small vapor bubble remaining. During a fire ceiling temperatures rise rapidly. The liquid absorbs the heat until it exceeds a specific temperature– most commonly 155° Fahrenheit - at which time the vapor shrinks and the liquid expands until the bulb breaks and activates the sprinkler with a gush of flame-retarding water.
For eg: Red colored liquid inside the bulb would indicate that the bulb will burst at 68 Deg Celcius and activate the sprinkler.
The time it takes for a bulb is dependent on temperature and bulb size. Bulbs are produced in two common sizes: 3 millimeter (mm) diameter or Quick Response and 5mm or Standard Response. A 3 mm bulb will break faster than a 5 mm bulb, though the time is measured in milliseconds and there is no discernable safety risk from using one versus the other. All Residential Fire Sprinklers are Quick Response bulbs.
Fire Sprinklers are commonly referred to by their bulb’s maximum temperature and are color coded.
· Orange: 135°F (58°C)
· Red: 155°F (68°C)
· Yellow: 175°F (80°C)
· Green: 200°F (94°C)
· Blue: 286°F (141°C)
· Purple: 360°F (182°C
