Results 1 to 6 of 6
Thread: How to Seperate a same boiling point mixture.
    hi
    can any tell me how to seperate a same boiling point mixutre. i would like to seperate Isopropyl Alcohol (90%w/w) and Acetonitrile(10% w/w). Iso Propyl alcohol -82.6 C (BP) and Acetonitrile - 81.6 C(BP)...is there any method to seperate this mixture...or any general method to seperate the solvents of Same Boiling point.
    Generally close boiling comp mixs are isomers . But IPA and acetonitrile are not. Thus you can use: Extractive distillation, azeotropic distillation, just extraction followd by distillation, membranes.
    I am sure ED should work here google for IPA-acetonitrile-extractive dist...
    thank you...plz upload if you have any good material on extractive distillation...
  6. Re: How to Seperate a same boiling point mixture.
    you can´t do it, you need first separate with solvent in one absortion one and then distillation o desorption in the next pass.
  7. Re: How to Seperate a same boiling point mixture.
    May this help you
    1. Extractive distillation design in hysys
    2. ADVANCED SIMULATION CASE USING HYSYS (from chapter 9 and above)
    One ED Review:
    but you need some specific...
  1. Composition of mixture
    By chaker05 in forum Oil And Gas Process
    Last Post: 12-25-2012, 02:27 PM
  2. Article: How to Seperate a same boiling point mixture.
    By naapranam in forum Home Articles
    Last Post: 12-22-2011, 07:32 AM
  3. Replies: 0
    Last Post: 11-04-2011, 10:41 PM
  4. Extractive Distillation: Separating Close-Boiling-Point Components
    By kumar_chemical in forum Oil And Gas Process
    Last Post: 04-17-2011, 06:36 AM
  5. Extractive Distillation: Separating Close-Boiling-Point Components
    By kumar_chemical in forum Petroleum Refining
    Last Post: 03-19-2011, 07:36 PM
