Page 1 of 2 1 2 LastLast
Results 1 to 12 of 17
Thread: ETAP USER Please SHARE
    Dec 2009
    Riau, Indonesia
    Hi dear all brothers,
    I have problem during use ETAP for motor starting simulation, it always ended up with this message
    Calculation proses terminated abnormally - Exit code - C000002B
    I can not solve it, it wont get through, any body can help me to find the problem?
    for information The files is pass for
    a. loadflow study
    b. short circuit study
    Please help, I need to do the simulation urgently.
    Thanks in advance.
    Rudi Tua
  3. Rudi,
    It is difficult us to guide by looking only into the error message.
    If you did any changes in the motor, undo with old data and run it. If they are ok with old data, just do the analysis with new data before enter in the model.
    or just zip the model and give me a link to analysis.
    Sorry.
    Dec 2009
    Riau, Indonesia
    Quote Originally Posted by etapexpert View Post
    Rudi,
    Sorry.
    Hi Etapexpert,
    I can not undo it, its been weeks I have repair my data (unfortunely, without doing simulation & cross check after any changes) in order to complete relay protection system and add some motor data on the system ... pity ...., but when I open my old data (that I have save it separately), the motor starting simulation works fine, still can not solve it.
    I have tried to dis----- all load exclude the motor I want to start, so that the generator is only supply the motor ... it also stuck with "terminated process", and then I tried to start another motor, and the generator is only supply that started motor, it also stuck ... so then I think it is about the generator spec, then I try to change the "in operation" generator ... and got the same result.
    then I copy the generator from different files (old file, that is working fine for start motor simulation), it is also stuck.
    can you help me explain what to do?, or at least please explain the meaning of the error message, and BTW do you have the list of ETAP error message with the meaning?
    Dec 2009
    Riau, Indonesia
    My files is more than 180mB, and it is difficult to upload my files in that size.
    Dec 2009
    Riau, Indonesia
    Quote Originally Posted by mshakeel44 View Post
    Hi mshakee144
    stop bothering thread with your duplication post, it is not worth to have much post just by duplicate it.
    I have check that you post duplicate posting everywhere on unrelated matter, how about creating your own thread, and post everything you have, so that when anybody who knows your posting is valuable, then every body will thank you for that.
    But anyway .. Sorry brother
    Rudi Tua
  10. Rudi,
    You won or not ?
    It is more than a year i did motor analysis.
    I have some clues.
    open the motor data in the old model, pick carefully all the data.i like to take a screenshot per setting page.
    again open the new model , the motor data.
    check and compare both.
    you will find where u went wrong.
    still not getting ? are you an member in linkedin ? make it if not. join etap group. post your question there. you may find some geniuos there.
    (my self an expert but i am not really an expert in etap. sorry !!)
    Dec 2009
    Riau, Indonesia
    Hi Etapexpert,
    Thanks for keep in touch,
    one weird step I found to solve the problem, is that ... when ever I open my old files, and the motor starting is working fine, then I open the files with "problem", and it works fine, but it just happened for one time, can not do for the second nor third.
    I also suspect that motor might be the problem, because I add more motor on the system, so then I go simulation with different loading type, then it works .... wow ... so one or more of my motor loading spec is the problem, but the question is "which one" .... arrrrgggh.
    My friend, is there any way to seek which load is the problem?, and more more .... is there any easy way to set motor/load loading scheme in spreadsheet mode (or other way), compare to change the setting one by one in etap pages?
    Thanks my friend, I am still keep trying.
    My best regards
    Rudi Tua
    Dec 2009
    Riau, Indonesia
    Rudi,
    You won or not ?
    I have some clues.
    thanks for the advice about linkedin, I will try.
  13. Ok. you like to see which one is gives trouble you ?
    you can switch off all the motor. run by switch it on one by one. so that you can find which one is in error page.
    You said, when you run first time it stimulate ok but it gives error if you run it further.
    mmm..... i am sorry rudi.
  14. #11
    Dec 2009
    Riau, Indonesia
    Thanks Etapexpert,
    I will try any more steps.
    Thanks again.
  16. #12
    Dec 2009
    Riau, Indonesia
    Hi dear friends,
    One funny question.
    Did any one have had a clue to change the ETAP 7.5 serial number that shows at the etap reports? besides hide it?
    Rudi Tua
  1. ETAP User Guide 11 or 12 plz
    By etapexpert in forum Electrical & Power Engineering
    Last Post: 03-08-2015, 06:38 AM
  2. Do you have ETAP calculation approved by your client ? Please share with me.
    Last Post: 12-26-2012, 05:19 PM
  3. Please share Centrifugal Pump User's Guidebook
    By milca84 in forum Pipeline And Fluid Flow
    Last Post: 10-02-2012, 08:51 PM
