Thread: pipeline anchor block calculation
  1. pipeline anchor block calculation
    I need help for pipeline anchor block calculation, please can someone show me this:
    with ceasar II I found force on X and z par example 900 KN at node anchor block; how to do for costruction for this support?
  3. it is important to have data from the soil. the area of thrust block must have the anchor depends on the resistance offered by the soil. This area must bear the full thrust of the pipeline.
  5. anchor bloc design
    thank you ...
    during pipeline construction, in the engineering, it's request when a pipeline connect with afcility, we put an anchor block..
    we have all informations about this :
    pressure,température , diameter, material, soil density, coef of friction of the sol..etc...
    the dimensiosn of the block are not the same ( wter lines, oil lines and gas lines)
    I am sur that the design is the same but tehe results depend from temperature and pressure of pipe...
    can you have me this formula , or any book design...
    regards
  6. Re: anchor bloc design
    Quote Originally Posted by galant1960 View Post
    thank you ...
    regards
    Hi again, casually I did some time ago a calculation for anchor blocks, it hasn't been validated yet but the results seem logical. Send me your e-mail for share it.
    Eddie
  1. pipeline calculation excel spreadsheet
    By mecasera in forum Engineering Spreadsheets & Presentations
    Last Post: 01-20-2019, 02:15 PM
  2. Pipeline Mainline Block Valve
    By kaliwaal in forum Pipeline And Fluid Flow
    Last Post: 07-23-2013, 04:10 AM
  3. Pipeline crossing calculation
    By AYAZUDDIN in forum Pipeline And Fluid Flow
    Last Post: 03-08-2013, 09:49 PM
  4. Pipeline Lay Tension Calculation
    By djmal in forum Pipeline And Fluid Flow
    Last Post: 10-12-2011, 04:52 AM
