Thread: Article: PSV sizing for gas blowby case
    You can view the page at
  3. Assumption : There is an upstream vessel and through a liquid or L/V control valve, fluid is transferred to a lower pressure Downstream vessel which needs to be protected for GBB.
    Easy Step : Consider upstream vessel design pressure - Downstream vessel design pressure = DP across the control valve.
    Estimate the gas flow through the control valve at that DP, SIxe the PSV for that gas flow.
    Rigorous step : Since the above step indicates many failures at the same time (more than double jeopardy), we can fine tune the situation to a single jeopardy situation and estimate some what less amount of gas flow requirement during GBB.
    A dynamic study is involved to do this calc; steps are below
    Step 1: consider normal liquid level in the upstream vessel, at design pressure. This liquid needs to be drained off to DS vessel before you start the GBB; Assumption : feed stopped due to Pressure / level switches actuation. Otherwise it is difficult to have GBB as you have liquid and gases flowing in.
    Step 2: Estimate the actual pressure now in the US vessel after draining off complete liquid from the vessel.
    Step-3: Now the upstream vessel pressure - DS vessel pressure is the system DP. This has to be consumed by all fittings between the both vessels. Calculate the fraction needs to be conumed across the control valve.
    Step -4: calculate the Gas flow at this DP, which will be some what less to the other easy step.
    Size the PSV for this gas load.
    Hope this help.
  1. Blow Case Sizing
    By rsampath in forum Oil And Gas Process
    Last Post: 08-07-2014, 05:25 PM
  2. PSV sizing sheet for gas filled vessel for fire case
    By hadeesf in forum Oil And Gas Process
    Last Post: 04-10-2014, 10:04 AM
  3. PSV sizing for gas blowby case
    By kath in forum Oil And Gas Production
    Last Post: 12-08-2011, 01:25 AM
  4. Article: Case Study for ZERO FLARE
    By samrat in forum Home Articles
    Last Post: 05-13-2011, 02:35 PM
  5. Article: Help with hysys case please
    By saifthamer83 in forum Home Articles
    Last Post: 04-27-2011, 10:23 PM
