Page 1 of 2 1 2 LastLast
Results 1 to 12 of 19
Thread: Qa/qc (itp) plan for tank
  1. Qa/qc (itp) plan for tank
    I need to make an QA/QC plan for the construction of an above ground storage tank.
    I have only for piping, could you give an example of a ITP for a tank?
    Thanks in advance!
    TEO
    teoscooter@yahoo.gr
  3. Re: Qa/qc (itp) plan for tank
    you shall inform Tank design standard code. ITP depend on standard.
    Jun 2008
    Karachi, Pakistan
    I searched for a suitable ITP, Method Statement and Inspection Format for Inspection of aboveground Storage Tanks but could not fine.
    However, the following three Standards two from Shell and one from Chevron can assist you to a great extent. Problem is that you will have to formulate the Inspection documents yourself from these. Assuming you are a mechanical engineer, and may already possess these, still I believe they can be useful.
    • DEP 34.51.01.31-CSPC CNOOC and Shell Petrochemicals Complex Project - Technical Specification Standard Vertical Tanks - Selection, Design and Fabrication
    • DEP 64.51.01.31-CSPC CNOOC and Shell Petrochemicals Complex Project - Technical Specification Standard Vertical Tanks- Field Erection and Testing
    • !000 Chevron Tanks Inspection and Testing.
    The documents are available on
    [link Point to another website Only the registered members can access] The fourth document on the URL is for Control Systems Engineers.
    By the way I am a Control Systems Engineer and well versed in QA QC for new Projects. If you keep me posted on the preparation of Quality Documents, I can be of more assiatance.
    Sajid Ali Khan
    Engineersajid52@gmail.com
  6. Re: Qa/qc (itp) plan for tank
    Dear Sajid!
    The file of the above link no longer exists, could you share it again or send it to geosterre@gmail.com
    thank you
  7. Re: Qa/qc (itp) plan for tank
    Dear Sajid!
    thank you
    Jul 2010
    Bangladesh
    Blog Entries
    2
    File not found. Pls upload again.
    Jun 2008
    Karachi, Pakistan
    Dear All,
    I have checked, even downloaded one file to verify.
    Links are OK, and files are there.
    Try clicking directly on the url
    [link Point to another website Only the registered members can access] It is possible that during pasting a part of the url was truncated. Try now on the above.
    Sajid Ali Khan
  11. Re: Qa/qc (itp) plan for tank
    I have followd your instructions, but I got:
    "The file link that you requested is not valid".
    regards
    file not available!!!
    Jul 2010
    Bangladesh
    Blog Entries
    2
    Quote Originally Posted by Sajid Ali Khan View Post
    Dear All,
    Sajid Ali Khan
    Would you mind to see the attached screenshot? It will tell the story.................
  14. #11
    file not available
    please upload again
    ----irfpat.
  16. #12
    Jun 2011
    Indonesia
    plzz share direct 2 file....tx
  1. lifting plan for prewelded umbrella tank roof
    By Eman1 in forum Civil & Structural Engineering
    Last Post: 01-15-2014, 08:08 AM
