To all Interested Forum Members,
I have done simulation in Hysys on Natural Gas Compression using Reciprocating Compressors. I am attaching the Process Flow Diagram (PFD) in *pdf to understand the process cycle. The compressor train consists of:
1. Suction Knock Out Drum(KOD)
2. Reciprocating Compressor
3. Air Cooler
4. Discharge KOD
The above is repeated for further stages of compression as can be seen in PFD. On each stages of compression there is an additional feed of gas , which has been shown attached to Mixer. The KODs drains are shown now as open to atmospheric pressure, though in practice are being taken to a common pipe header and then re-flashed to Suction KOD. Suction KOD drain is channeled to a separate independent stream, which at present shown open for running basic simulation.
Question: I am unable to run this simulation, though all relevant parameters have been filled up, except air flow in Aircooler, which I am not aware at present. But for sizing purpose, have only indicated the pressure drop in cooler, as well as air inlet temperature and gas outlet temperature.
I would be glad to learn the tricks of the trade of this simulation if any one volunteers to help me. Please let me know to further dialogue on this subject matter. I am prepared to share the information if genuinely members co-operate.
The attachment link is:
samrat
