Thread: spiral pipe prefarable angle for each pipe diameter
  1. spiral pipe prefarable angle for each pipe diameter
    please i need your help urgently i have an offer for pipe spiral pipe and i dont have the prefarable angle is should work with for each pipe diameter and i need to calculate the needed steel coil width for each pipe but i need to know the angle to get the B factor the coil width (the used steel quality will be API 5L Gr B , and S235JR)
    D t
    269.032 7.93
    322.872 9.53
    372.872 9.53
    455.8 10
    524 10
    582.8 10
    your co-operation is highly appreciated
  3. also we have four work offers if any one is interested on them with a good salaries more than 2500 $ per month + accommodation
    Slitting line Mgr
    ERW line Mgr
    Spiral line Mgr
    coating line Mgr
  1. Spiral welded pipe or longitudinal?
    By pipeline in forum Pipeline And Fluid Flow
    Last Post: 06-23-2010, 03:30 PM
  2. pipe diameter
    By WAT in forum Pipeline And Fluid Flow
    Last Post: 08-20-2009, 06:47 AM
  3. Forces Due To Pipe Bend And/Or Diameter Changes
    By Freeman in forum Pipeline And Fluid Flow
    Last Post: 12-06-2008, 11:33 PM
