Results 1 to 1 of 1
Thread: help for high pressure feed water in power plant
    May 2011
    Hyderabad, Andhra Pradesh, India
    hai to all..
    i want to design a shell and tube heat exchanger feed water heater in htri but when i am trying it it is getting an error,
    can anyone please do the problem for me
    this is my problem
    data given
    Inlet steam flow rate =5.060 t/hr
    Inlet steam flow temperature=252.8°C
    Outlet steam flow temperature=129.9°C
    inlet pressure of steam = 8.669 ata
    feed water flow rate =60t/hr
    feed water inlet flow temperature=121.3°C
    feed water outlet flow temperature=169.3°C
    shell side steam
    tube side water
    will anyone please do the problem and send me the file...
    my email kumars876@gmail.com
  1. Ask - use HDPE material for thermal power plant water supply
    By convitco in forum Pipeline And Fluid Flow
    Last Post: 01-24-2014, 12:54 PM
  2. Cooling water system for Coal‐fired Thermal Power plant
    By kla in forum Pipeline And Fluid Flow
    Last Post: 01-15-2014, 04:52 AM
  3. High pressure feed water heaters
    By abc123 in forum Mechanical Engineering
    Last Post: 12-13-2012, 07:31 AM
  4. Power plant HP feed water heater
    By A.Venugopal in forum Mechanical Engineering
    Last Post: 11-07-2009, 08:04 PM
