Thread: Design of Reinforced Concrete: ACI 318-05 Code Edition, 7th Edition_Mediafire
    Seventh Edition
    by Jack C. McCormac
    and James K. Nelson
    Code:
    Mediafire unlock password: nhawe
    When it comes to reinforced concrete design, one text stands out as the clear and accessible choiceesign of Reinforced Concrete.
    With this bestselling book, readers will quickly gain a better understanding of the fundamentals of reinforced concrete design. The authors present a thorough introduction to the field, covering such areas as
    • theories
    • ACI Code requirements
    • the design of reinforced concrete beams, slabs, columns, footings, retaining walls, bearing walls, prestressed concrete sections, and framework
    • numerous examples are also integrated throughout the chapters to help reinforce the principles that are discussed
    Contents
    1. Introduction
    2. Flexural Analysis of Beams
    3. Strength Analysis of Beams according to ACI Code
    4. Design of Rectangular Beams and One-Way Slabs
    5. Analysis and Design of T Beams and Doubly Reinforced Beams
    6. Serviceability
    7. Bond, Development Lengths, and Splices
    8. Shear and Diagonal Tension
    9. Introduction to Columns
    10. Design of Short Columns Subject to Axial Load and Bending
    11. Slender Columns
    12. Footings
    13. Retaining Walls
    14. Continuous Reinforced Concrete Structures
    15. Torsion
    16. Two-Way Slabs, Direct Design Method
    17. Two-Way Slabs, Equivalent Frame Method
    18. Walls
    19. Prestressed Concrete
    20. Formwork
    21. Reinforced Concrete Building Systems
    Tables and Graphs: U.S. Customary Units
    Tables in SI Units
    The Strut-and-Tie Method of Design
    Glossary
    Index
  3. thanks
    Re: Design of Reinforced Concrete: ACI 318-05 Code Edition, 7th Edition_Mediafire
    Hi, can you share again? Link is off :/
  1. Structural Concrete: Theory and Design, 4th Edition_Mediafire
    By Poisoner in forum Civil & Structural Engineering
    Last Post: 12-14-2013, 10:57 PM
  2. Design of Concrete Structures by Arthur H. Nilson - 14th Edition_Mediafire
    Last Post: 09-13-2012, 10:56 AM
  3. Handbook of Concrete Engineering 2nd Edition_Mediafire
    Last Post: 12-04-2011, 09:07 AM
  4. Design and Analysis of Heavily Loaded Reinforced Concrete for Burj Dubai_MF
    Last Post: 11-04-2011, 09:24 AM
  5. Design of Reinforced Concrete Structure – Vol. 1,2&3_Mediafire
    Last Post: 11-04-2011, 09:16 AM
