Hi all
does anyone has serial number for PVELITE 2011?
TA
Hi all
TA
interested
Can any one provide the solution / ******** for the hardware lock for PVelite 2011 software, without which the SL. No. will be of no use.
Thanks in advance.
Please share the ********. Thanks in advance.
please upload pvelite 2011 with ********
Follows are steps I was tried when install PVElite2010 and finally it look working. I am not sure which step make it work but you can try it and inform me.
1. Install pvelite 2010 demo from intergraph but there is limitation in internal pressure (not changeable value) ---> useless
2. Then I download "solution" PVelite 2010 from 4shared using SPLM option (follow thread "PVElite 2010 download link here" from egpet), but should buy licence code from "solution" --->not working
3. Copy files from installed PVElite 2010 Demo to installed non-demo --->not working
3. Install PVElite 2008 emulator only ---> still not working
4. Run C:\Program Files\COADE\PVElite 2010\Assidrv\trial-1.bat ---> still not working
5. Uninstall "solution" PVelite 2010 and reinstall it using "green dongle" option ---> LOOK WORKING, I can create, edit, open, etc but need more test to make it sure
Good luck
yes, i've succeeded in installing pvelite 2010 in windows 7 32-bit and so far it's good. I don't know how i've done it. Also tried installing it in my windows 7 64-bit notebook but nothing happened. has anybody successfully installed theirs in 64-bit windows 7?
Please share source and m-e-d-i-c-i-n-e. Thanks in advance.
Alway like it...........
If you need PVElite 2008/2010 you can follow "bejana-tekan.blogspot.com/2011/08/pvelite.html" or googling for the smaller file "PVelite 2010 solution 4shared" (200MB splitted in 41 files, you need hjsplit to re-join it)
PVElite 2011/2012? I need it too...
what language is used here in the above website?
