Page 1 of 2 1 2 LastLast
Results 1 to 12 of 13
Thread: ASME B16.49 2007 required urgently plz
  1. ASME B16.49 2007 required urgently plz
    Hi Everyone,
    I am looking for ASME B16.49 2007 factory-made wrought steel buttwelding induction bends for Transportation and Distribution Systems.
    Your help will be greatly appreciated
  3. Quote Originally Posted by mohammed21 View Post
    Hi Everyone,
    ASME B16.49 Ed.2007
    Thanks Mr. Welding inspector
    May 2008
    Al-Jubail, saudi arbia
    Re: ASME B16.49 2007 required urgently plz
    Please upload again Asme B16.49 Latest Standard
    Thanks in advance
  7. Re: ASME B16.49 2007 required urgently plz
    Please upload again
  9. Re: ASME B16.49 2007 required urgently plz
    Asme b16.49 - 2007
    Attached Files Attached Files
    Mar 2011
    Portugal
    THX aabdulaslam!
    I work at an induction bending company and deal a lot with ASME B16.49, ISO 15590-1 and other relevant specifications. If you have any questions please do not hesitate to ask me.
    Quote Originally Posted by mookins View Post
    ok, I have a question, how do they calculate reduction in area when testing bends for hardness value etc. what are acceptable numbers for reduction in area?
  14. #11
    Hi Palmeto,
    When you say hardness value, I presume you actually mean ductility. The hardness measurements (Vickers, Brinell etc) are a separate issue again.
    With regard to the reduction of area, it is the same for any tensile test. However the preparation of samples for tensile testing of induction bends is difficult because your samples have curvature in two axes.
    Acceptable values for reduction in area are entirely at the discretion of the purchaser. They will specify the mechanical properties that they wish to achieve and the induction bending company will formulate a manufacturing procedure in accordance with ISO 15590-1 or ASME B16.49 which achieves the desired properties. It is typical to try to bring the material back to that of the parent material (pipe) specification.
    An example would be API Specification 5L X70M PSL2 welded; here we would aim to achieve the same properties as specified in the linepipe specification by applying the requirements of ISO 15590-1. ISO 15590-1 deals directly with ISO 3183/API Specification 5L so they are a natural fit for each other.
    I also apologise for the long delay, I have been on vacation.
  16. Re: ASME B16.49 2007 required urgently plz
    Please reupload
    Greetings
    Abo Khaled
  1. Asme a13.1 2007
    By ads19 in forum Pipeline And Fluid Flow
    Last Post: 12-04-2013, 12:52 PM
  2. Required ASME B73.1-2007
    By Muhammad Ramzan in forum Mechanical Engineering
    Last Post: 03-11-2013, 04:34 AM
  3. REQUIRED : ASME Section II (Part A To D) 2007
    By simpanbuku in forum Mechanical Engineering
    Last Post: 07-17-2012, 04:18 PM
  4. ASME B 16.42 required urgently
    By saahil in forum Mechanical Engineering
    Last Post: 09-01-2011, 09:00 PM
  5. ASME B 16.42 required urgently
    By saahil in forum Safety And Environment
    Last Post: 09-01-2011, 08:51 PM
