Results 1 to 9 of 9
Thread: Machine Design Databook
    by: K. Lingaiah
    1344 pages
    Product Description
    *No fluff here - with over 95% of data in the form of charts, tables and formulas, this "pure" data book is designed for easy referencing of codes and standards *Over 300 pages of new material, including new chapters on machine tool design, applied elasticity, locking machine elements, and retaining rings *Includes the latest codes and standards from ASME, AGMA, BIS, ISO, DIN, and more
    From the Back Cover
    THE FORMULAS AND DATA YOU NEED TO SOLVE EVEN THE MOST COMPLEX MACHINE DESIGN PROBLEMS!
    Utilizing the latest standards and codes, Machine Design Databook, Second Edition is the power tool engineers need to tackle the full range of machine design problems. Packed with valuable formulas, tables, charts, and graphs this unique handbook provides information in both SI and US Customary units--more data than any other similar reference available today! Selecting the appropriate formula and locating the necessary information has never been easier ... or faster!
    With over 300 pages of additional material, Machine Design Databook, Second Edition has new chapters on:
    * The Elements of Machine Tool Design
    * Applied Elasticity
    * Locking Machine Elements
    * Retaining Rings
    TURN TO MACHINE DESIGN DATABOOK, Second Edition FOR:
    * The latest Codes and standards from ASME, AGMA, BIS, ISO, DIN, and more
    * Cutting-edge information on application of the latest analytic techniques in gear design
    * Charts on material properties
    * Calculations of friction, wear, and lubrication of sliding and contact bearings
    * Determination of axial load, torsion, and bending moment for shafts
    * The design of couplings, clutches, and brakes
    * Formulas (empirical, semi-empirical, and otherwise)
    * The latest advances in tool design and composite materials
    * And much more!
    On the drafting table, at the workstation, and in the shop, here is the one-stop solution to all of your machine design problems.
    Table of Contents
    Preface
    Acknowledgments
    1 Properties of Engineering Materials 1.1
    2 Static Stresses in Machine Elements 2.1
    3 Dynamic Stresses in Machine Elements 3.1
    4 Stress Concentration and Stress Intensity in Machine Members 4.1
    5 Design of Machine Elements for Strength 5.1
    6 Cams 6.1
    7 Pipes, Tubes, and Cylinders 7.1
    8 Design of Pressure Vessels, Plates, and Shells 8.1
    9 Design of Power Boilers 9.1
    10 Rotating Disks and Cylinders 10.1
    11 Metal Fits, Tolerances, and Surface Texture 11.1
    12 Design of Welded Joints 12.1
    13 Riveted Joints 13.1
    14 Design of Shafts 14.1
    15 Flywheels 15.1
    16 Packings and Seals 16.1
    17 Keys, Pins, Cotters, and Joints 17.1
    18 Threaded Fasteners and Screws for Power Transmission 18.1
    19 Couplings, Clutches, and Brakes 19.1
    20 Springs 20.1
    21 Flexible Machine Elements 21.1
    22 Mechanical Vibrations 22.1
    23 Gears 23.1
    24 Design of Bearings and Tribology 24.1
    25 Miscellaneous Machine Elements 25.1
    Appendix A Measurement Units and Conversion Tables 1
    Appendix B The Greek Alphabet 1
    Appendix C References 1
    Index 1
    Download :
  3. thanks dude
  5. thank you very much dude..
  6. Re: Machine Design Databook
    Links not working, can somebody helpme
    Requested
  9. Re: Machine Design Databook
    The link is dead, can you please re-send a new link or email me at raksh1980@gmail.com
    Link**
    [link Point to another website Only the registered members can access] Click Get
  11. Re: Machine Design Databook
    [link Point to another website Only the registered members can access] use this
  12. Re: Machine Design Databook
    Thanks! haroub_nas / gasoil
  1. Fundamentals of Machine Design
    By AnandV in forum Mechanical Engineering
    Last Post: 06-23-2015, 05:42 PM
  2. Standard Handbook of Machine Design
    By akhileshk29 in forum Mechanical Engineering
    Last Post: 03-07-2013, 07:03 AM
  3. Fundamentals of Machine Design Vol. I
    By selmagis in forum Mechanical Engineering
    Last Post: 10-30-2011, 10:40 PM
  4. Machine Design
    Last Post: 01-17-2011, 06:57 AM
