Can someone provide a hysys case showing the following crude defined in the oil environment?[link Point to another website Only the registered members can access]
Your help would be most appreciated, thanks.
Dear almmohd,
I have not access to the link that you have posted!
Maybe this video tutorial will help you :
Link: [link Point to another website Only the registered members can access]
you should copy the link in your browser,I think the redirection does not work in the forum.
Regards.
there is complete tutorial in hysys about crude oil characterization....it will be in the doc..tutapps.pdf is file name...check and carry on ur project
I think I got it modelled right.... the model results doesn't match the real crude column... guess I have some tweaking to do
hi
you may check this link and down load the file...you will find complete tutorial on the crude assay
