Results 1 to 6 of 6
Thread: Gas lift injection rate and pressure calculation
  1. Gas lift injection rate and pressure calculation
    Dear all,
    I would like to calculate the required Gas lift injection rate and pressure to compare them with the existing gas lift system. Does anyone have a procedure to make such calculations other than the gas lift design procedure.
  3. any reply ?
    What do you have as Input Data?
  6. I have all the data of the well and the surface facility, all the data I need
    You can use the Quicklook option of Prosper to troubleshoot ur gas lift system and optimze if necessary!
  9. Quote Originally Posted by ELgharib View Post
    thank you for your reply but I am looking for a detailed step by step guide to make hand calculation.
  1. Gas Lift & Injection Facilities
    By Rajalakshmi in forum Oil And Gas Production
    Last Post: 03-24-2014, 06:46 AM
  2. Article: Gas flow rate through Gas lift Valve
    By avinavgautam in forum Home Articles
    Last Post: 07-26-2011, 10:16 PM
  3. Replies: 0
    Last Post: 09-29-2010, 01:26 AM
  4. Replies: 0
    Last Post: 09-28-2010, 01:28 PM
