clorine dry service valves _Pamphlet 006,Ed 14 _Dec 1998_.pdf
eurochlor_gest 73-25 TRANSPORT OF CHLORINE BY LONG DISTANCE PIPELINE.pdf
1) GEST 76/64 - Relief Valves for Use on Dry Gas or Liquid Chlorine
2) GEST 80/85 - Code of Good Practice for Installation Removal and Maintenance of Manually Operated Chlorine Valves
3) GEST 86/128 - Procedure for Homologation of Valves for Use on Liquid and Dry Gaseous Chlorine
4) GEST 89/140 - Specification for Flanged Steel Globe Valves-Bellows Sealed -for Use on Liquid Chlorine
5) GEST 90/150 - Specification for Flanged Steel Globe Valves - Packed Gland - for Use on Liquid Chlorine
6) GEST 93/180 - Specification for Flanged Steel Ball Valves - Packed Gland - for Use on Liquid Chlorine
7) GEST 94/207 - Code of Practice for the Installation of Pressure Sensing Devices on Dry Gaseous and Liquid Chlorine Applications
8) GEST 94/210 - Code of Practice for the Installation of Flow Measuring Devices on Dry Gaseous and Liquid Chlorine Applications
9) GEST 94/213 - Guidelines for the Selection and Use of fixed Chlorine Detection Systems in Chlorine Plants
10) GEST 98/245 - Specification for Process Control Valves (Bellows Sealed) for Use on Liquid Chlorine
11) GEST 98/247 - Specification for Remotely Operable Shut-Off Valves Bellows Sealed for Use with Liquid Chlorine
12) TSEM 05/299 - On-Line Determination of Nitrogen Trichloride In Solvay Chlorine Production Units (Neil Breton)
13) TSEM 08/329 - Chlorine valves recommendations (M. Jessop)
Read more:
