Results 1 to 5 of 5
Thread: Pressure Test equipment
    Hi
    I need to drawing or picture for 15000 psi pressure testing equipment (medium:water ,hydraulic & nitrogen test)
    Thank you.
    Hi
    Based on ASME B31.3 , the formula for Hydraulic Test is P(test)=1.5 * P(Design) and for Pneumatic test P(test) = 1.1 * P(Design) , but you must consider that test temperature must be same design temperature , also there are some more points , it is better read ASME B31.3 ,
    Please post your questions if there is any ,
    Feb 2011
    saudi arabia
    Hi Netspyking
    I think his referring to the test equipment and not the equation.
    Pressure Test equipment here is link...
    Cy
    Please if there s proceder for calibration pressure gauge
    Send your e- mail to me , i will reply you.
  1. Pressure Equipment Directive
    By lochandadhich in forum Mechanical Engineering
    Last Post: 02-25-2012, 01:34 PM
  2. Pressure Equipment.
    By Mr Welder in forum Mechanical Engineering
    Last Post: 06-24-2011, 08:43 AM
  3. European Pressure Equipment
    By praphulla.phirke in forum Mechanical Engineering
    Last Post: 11-16-2009, 10:02 PM
  4. Pressure Equipment Directive EC 97/23
    Last Post: 02-06-2009, 10:38 PM
