Thread: Eemua publications
    Eemua publications
    Dear Members
    I'm looking for EEMUA publication as listed below. Your contribution is highly appreciated and may ALLAH bless you
    - 211 Guidance on the specification of pressure vessels
    - 223 Pressure Equipment Testing after Repair, Modifications or Re-rating: A Guide to the Pressure Test Waiver
    - 168 A Guide to the Pressure Testing of In-service Pressurised Equipment
    - 215 Industrial Cooling Tower Fans and Fin Fans - Guide for Design, Maintenance and Operation
    - 208 Guide to life-cycle management of pressure relief systems
    - 205 A Guide to the Production Testing of Valves for the Energy, Process and related Industries
    - 204 Piping and the European Pressure Equipment Directive: Guidance for Plant Owners/Operators
    - 200 Guide to the Specification, Installation and Maintenance of Spring Supports for Piping
    - 199 On-Line Leak Sealing of Piping: Guide to Safety Considerations
    - 188 Guide for Establishing Operating Periods of Safety Valves
    - 185 Guide for Hot Tapping on Piping and other Equipment
    - 184 Guide to the Isolation of Pressure Relieving Devices
    - 179 A Working Guide for Carbon Steel Equipment in Wet H2S Service
    - 143 Recommendations for Tube End Welding: Tubular Heat Transfer Equipment Part 1 - Ferrous Materials
    - 197 Specification for the Fabrication of Non-Primary Structural Steelwork for Offshore Installations
    - 194 Guidelines for Materials Selection and Corrosion Control for Subsea Oil and Gas Production Equipment
    - 176 Specification for Structural Castings for use Offshore
    - 146 90/10 Copper Nickel Alloy Piping for Offshore Applications - Specification: Fittings
    - 145 90/10 Copper Nickel Piping for Offshore Applications - Specification: Flanges Composite and Solid
    - 144 90/10 Copper Nickel Alloy Piping for Offshore Applications - Specification: Tubes Seamless and Welded
    - 217 Safe and effective operation of storage tanks
    - 207 Double concrete tanks for liquefied gas – guide to design, construction and operation
    - 190 Guide for the Design, Construction and Use of Mounded Horizontal Cylindrical Steel Vessels for Pressurised Storage of LPG at Ambient Temperatures
    - 183: Prevention of tank bottom leakage - a guide for the design and repair of foundations and bottoms of vertical, cylindrical, steel storage tanks
    - 180 Frangible Roof Joints for Fixed Roof Storage Tanks: Guide for Designers and Users
    - 159 Users' Guide to the Inspection, Maintenance and Repair of Above ground Vertical Cylindrical Steel Storage Tanks
    - 154 Guidance to Owners on Demolition of Vertical Cylindrical Steel Storage Tanks and Storage Spheres
    - 147 Recommendations for the Design and Construction of Refrigerated Liquefied Gas Storage Tanks
    - 206 Risk Based Inspection - A Guide to Effective Use of the RBI Process
    - 149 Code of Practice for the Identification and Checking of Materials of Construction in Pressure Systems in Process Plants
    - 105 Factory Stairways, Ladders and Handrails (including Access Platforms and Ramps)
    me too
    Re: Eemua publications
    i need it too
  1. New EEMUA publications
    By mhenna in forum Oil And Gas Process
    Last Post: 03-26-2018, 04:06 AM
  2. Eemua publications required
    By amshah in forum Instrumentation & Control
    Last Post: 03-24-2015, 10:57 AM
  3. API New Standard Publications
    By Shabbir2009 in forum Pipeline And Fluid Flow
    Last Post: 03-10-2015, 08:06 AM
  4. ISA & Instrument Publications
    By Abdel Halim Galala in forum Instrumentation & Control
    Last Post: 01-15-2012, 08:33 AM
  5. Special Publications
    By rancio in forum Geology & Exploration
    Last Post: 07-18-2010, 01:21 AM
