kindly post the procedure to install the etap 7 on win 7 x64 .....
THNX
THNX
m stuck with my project on power system protection..... i need to work on etap 7... i have win 7 x64 installed on my laptop...
anyone kindly post the procedure to install etap 7 on win 7 x64 machine....
Thanks.....
if you are working with power system protection i suggest to use CAPE instead of ETAP.. etap only simulates overcurrent studies. if you are only referring to overcurrent issues then ETAP would be ok.
1. Disable connection to internet
2. Disable antivirus software on your computer
3. Run Etap-7 installation
4. select install + license manager, just follow the instruction.
5. When finish installation, dont run the software.
6. Open DRIVERS folder in downloaded file (\ETAPSETUP\LM32SETUP\LMSETUP\SYSTEM32\DRIVERS )
7. copy all files in that folder to C:Windows\System32\Drivers
8. Goto c:\Program Files\Operation Inc. Technology ETAP Licence Manager and open the file ETAPKEY.exe.
A window will keep running. Let it be running.
9. Now Go to ----- folder and run Etap7-----.exe . This is the software to bypass license.
this file is under DOS file, so you will see DOS application run.
10.After finish installing Etap7-----.exe, then Reboot your computer/laptop.
11.Enable again your antivirus
12.Run ETAp 7 application.
13.Will show up window for license , click OK, then software will ask for activation serial
Enter Activation serial :
%RZRSSNwC%Qrn%hRvCpRCw8+CvfpBx4tzfMu <------recomended print button enabled
or
%RZRSSNAC%Qrn%hZrCxRf3uk+khVaZP?i4QT
