Results 1 to 6 of 6
Thread: ASTM E428 and ASTM E127 are required
  1. ASTM E428 and ASTM E127 are required
    Hello Guys,
    I'm looking for ASTM E428 and ASTM E127.
    Appreciate your sharing
    Quote Originally Posted by mohammed21 View Post
    Hello Guys,
    ASTM E127-Ed.2006
    Standard Practice for Fabricating and Checking Aluminum Alloy Ultrasonic Standard Reference Blocks
    ASTM E428 Ed.2000
    Standard Practice for Fabrication and Control of Steel Reference Blocks Used in Ultrasonic Examination
    If you want other standards for ultrasound saw this post I started here:
  5. Thanks my friend, but it says Invalid or Deleted File, i think files only can live for 2 days. I appreciate if you are able to upload them again.
    Re: ASTM E428 and ASTM E127 are required
    current audit standards
  7. Re: ASTM E428 and ASTM E127 are required
    ASTM New Documents ....
    Document Number Date Title
    Thank you so much
  1. (Req) ASTM E10, ASTM E94, ASTM E140, ASTM E165, ASTM E709, EN 473
    By prasetyohse in forum Materials Science &Corrosion
    Last Post: 07-11-2019, 06:48 AM
  2. Replies: 13
  3. ASTM A262, ASTM G108 ASTM A923 are required
    By mohammed21 in forum Mechanical Engineering
    Last Post: 12-13-2014, 07:21 AM
  4. Replies: 2
    Last Post: 04-21-2013, 10:30 AM
  5. ASTM D5064 , ASTM D1730, ASTM D1731, ASTM D1732 are required!
    Last Post: 07-30-2012, 05:04 AM
