We have crude oil pipeline 2000 Ft X 4 In plugged with paraffin deposition , we need to clean it and put it in service again -any help or guide to procedure to follow
The following paper can help you in this problem
[table]
[TR]
[TD="class: td_pre_lbl"]Paper Number [/TD]
[TD="colspan: 5"]115658-MS[/TD]
[/TR]
[TR]
[TD="class: td_pre_lbl"]DOI
[/TD]
[TD="colspan: 5"]10.2118/115658-MS[/TD]
[/TR]
[TR]
[TD="class: td_pre_lbl"]Title[/TD]
[TD="class: td_pre_title, colspan: 5"] Successful Pipeline Clean Out—Lessons Learned From Cleaning Paraffin Blockage From a Deepwater Pipeline
[/TD]
[/TR]
[TR]
[TD="class: td_pre_lbl"]Authors[/TD]
[TD="colspan: 5"] Gary Poole, SPE, Gene Brock, SPE, Steve Szymczak, SPE, and Greg Casey, BJ Services Company
[/TD]
[/TR]
[TR]
[TD="class: td_pre_lbl"]Source[/TD]
[TD="colspan: 5"] SPE Annual Technical Conference and Exhibition, 21-24 September 2008, Denver, Colorado, USA
[/TD]
[/TR]
[TR]
[TD="class: td_pre_lbl"]Copyright[/TD]
[TD="colspan: 5"] 2008. Society of Petroleum Engineers
[/TD]
[/TR]
[TR]
[TD="class: td_pre_lbl"]Language[/TD]
[TD="colspan: 5"]English[/TD]
[/TR]
[TR]
[TD="class: td_pre_lbl_preview"]Preview[/TD]
[TD="class: td_pre_preview, colspan: 5"] Abstract
This paper presents a case history of inspecting, cleaning and re-establishing communication in a deepwater pipeline that had plugged because of paraffin deposition over an extended period. Early mitigation attempts did not remove the solid mass causing the blockage but, rather, compounded the problem.
A chemical capable of dispersing the wax mass was applied to the plugged pipeline through a snubbing unit. Access to the pipeline and the wax plug was gained by disconnecting the line at the subsea site, lifting the pipeline to a work rig, installing the snubbing unit and applying the chemical solution in sea water at a prescribed dilution ratio.
One critical step in dispersing and removing the solid wax mass was selecting the dispersant package. In addition, after the correct chemistry was identified, its application required a complex operation. A snubbing unit inside the pipeline jetted the chemical dispersant and drilled through the wax mass. The dispersed fluid was then returned to the working rig where the paraffins were disposed. The operation was successful and the pipeline was placed back into production. However, it was complicated by the ocean floor topography: The deepwater environment adds a degree of difficulty that is not experienced in shelf waters or on land. The exercise taught several lessons, the most significant being that a slow and consistent effort is ideal. Once the mass is dispersed it is best to continuously remove this fluid. Stop-and-start operations allow the solubilized mass to re-solidify as the solvent drains away from the mass under static conditions.
Although operators would like for all operations to proceed according to plan, unforeseen and undesirable situations arise. In the case of a plugged pipeline, several causes need to be investigated in order to prevent future occurrences. Operators need to know that operational experience combined with application chemistry exists to help unplug a deepwater pipeline.
Introduction:
This paper is about a pipeline plugging problem. The problems were technical, mechanical and chemical. The focus of the paper is selection and application of the correct paraffin dispersant chemistry that was then combined with the right mechanical application to solve the technical problem.
Solving problems in the oil field is always a challenge. Solving problems of an unknown or uncertain type complicate the challenge. In this case history a deepwater operator found himself with a pipeline plugging problem. It was not possible to identify the type of plug or its location in the pipeline. For that reason the operator went through a series of fixes using the method most probable to prioritize the sequence of solution operations. This was complicated in that a solution that does not remediate the problem may make a second attempt more complex. We surmise that in the first attempt to fix this particular problem, methanol was added to a hydrocarbon matrix and precipitated a hard wax. In the end, the quick fix approaches served to teach to people what would not work and led them to the right solution. In hindsight, it would be easy to second-guess the unsuccessful steps that were taken. However, it is best to appreciate this effort as a complicated process of elimination. In that type of process, it is best when the negative outcome can be used to better define an improved process that more efficiently results in the desired outcome.
[/TD]
[/TR]
[TR]
[TD="class: td_pre_lbl"]Number of Pages[/TD]
[TD="colspan: 5"]9[/TD]
[/TR]
[/table]
If you get it please share
