1.The reason may be the bearing get jammed due insuffucient lubricant.Please check the lubricating sytem.2. Any foreign material might enter into the casing and impeller.3. Impeller may be loosened due to anti-clock rotation of the driverHope these are all the reason the impeller may got jammed.If you found any one other than the above,pl share with meThanksS.K.Rajakumar
