Thread: International Plumbing Codes Handbook (2009)
    This book is your guide to getting your code questions answered with less stress. It is your ticket to simplifying the cryptic code that you work with on a daily basis. The code is large and can be complicated. I’ve translated the code into easy-to-use terms for people in the field. See the code as a real-world guide instead of some foreign language that only some people can begin to sift through.
    How important is understanding the code? It is essential for professionals in the trade. Building without code compliance is an expensive mistake. Many good builders and contractors mean well and still stray from the code. This is often due to the code being difficult to understand and follow. Not anymore. This book will walk you through the code requirements chapter by chapter.
    Laid out in the same basic sequence as the code book, this book can be used in conjunction with your code book. While this book is not a replacement for your code book, it is a strong enhancement to it. Use the books together as resources to make your job or your business more productive.
    Thumb through the pages here. Notice the tip boxes. You will find that some key components of the code are highlighted in the tip boxes. Go ahead, take a peek. While you are at it, pick a few topics that you are either familiar with or confused about, and look them up. See for yourself how easy this book makes it to put your mind at ease on code issues.
    Forum members are welcome to download from
    Best regards
    Aug 2009
    India
    Blog Entries
    11
    Re: International Plumbing Codes Handbook (2009)
    File deleted, dear.
    Hi,
    Try this :
    georgecis
    georgecis, thank you
  1. International codes 2009
    By mahdy 81 in forum Materials Science &Corrosion
    Last Post: 01-03-2018, 04:21 PM
  2. International Codes and Standards
    By bzbipin in forum Instrumentation & Control
    Last Post: 05-14-2016, 10:00 PM
  3. National Standard Plumbing Code 2009 illustrated
    By Abo Khaled in forum Mechanical Engineering
    Last Post: 08-16-2012, 09:19 AM
  4. 2009 nternational Plumbing
    Last Post: 03-05-2010, 04:32 PM
  5. International Codes, 2006 by International Code Council
    By AnandV in forum Mechanical Engineering
    Last Post: 03-23-2009, 09:46 PM
