New unit converter widget was installed as block in Forum Sidebar and community home page where we can use it as resource for unit converters,
Mass and Weight
Temperature
Velocity and Speed
Volume and Capacity
Engineering converters
Heat converters
Fluids converters
Light converters
Electricity converters
Magnetism converters
Radiology converters
Other converters
Length and Distance:
Inch , in
Foot , ft
Mile (US)
Yard , yd
Mile (US Survey Foot)
Nautical Mile , Nm
and others...
Mass and Weight:
Pound , lb
Ounce , oz
Stone , st
Stone (UK) , st
Grain , gr
Ton (long) , ton
and others...
Temperature:
Fahrenheit , °F
Celsius , °C
Kelvin , K
Réaumur , °R
Rankine , °Ra
and others...
Velocity and Speed:
Mile/Hour , mph
Foot/Second , ft/s
Foot/Minute , ft/min
Foot/Hour , ft/h
Mile/Second , mi/s
Mile/Minute , mi/min
and others...
Volume and Capacity:
Gallon , gal
Cubic Foot , ft³
Ounce , fl oz
Gallon (UK) , gal
Barrel (Oil) , bbl
Pint (UK) , pt
and others...
Engineering converters:
Acceleration - Angular
Acceleration - Linear
Angle
Area
Data Storage
Data Transfer
Density
Energy
Force
Moment of Inertia
Numbers
Power
Pressure
Specific Volume
Time
Torque
Velocity - Angular Heat converters:
Fuel Efficiency
Heat Capacity
Heat Flux Density
Heat Transfer Coefficient
Specific Heat
Temperature Interval
Thermal Conductivity
Thermal Expansion
Fluids converters:
Concentr. Liquid Solution
Concentration - Molar
Flow
Flow - Mass
Flow - Molar
Mass Flux Density
Permeability
Surface Tension
Viscosity - Dynamic
Viscosity - Kinematic
Light converters:
Digital Image Resolution
Frequency Wavelength
Illum. Luminous Intensity
Illumination
Luminance
Electricity converters:
Capacitance
Charge
Conductance
Conductivity
Current
Electric Field
Inductance
Linear Charge Density
Linear Current Density
Resistance
Resistivity
Surface Charge Density
Surface Current Density
Volume Charge Density
Magnetism converters:
Magnetic Flux
Magnetic Flux Density
Magnetomotive Force
Radiology converters:
Radiat. - Absorbed Dose
Radiation
Radiation - Activity
Radiation - Exposure
Calorific Value
Chemical - Henry's Law
Currency
Entropy
HVAC Efficiency
Latent Heat
Sound
Typography
Volume - Dry
Volume - Lumber
Other converters:
