Pipe is made of a wide variety of materials - like galvanized steel, black steel, copper, cast iron, concrete, and various plastics such as ABS, PVC, CPVC, polyethylene, polybutylene and more.
Pipes are identified by "nominal" or "trade" names that are loosely related to the actual dimensions. For instance, a 2-inch galvanized steel pipe has an inside diameter of about 2 1/8 inches and an outside diameter of about 2 5/8 inches.In plumbing pipe size is referred to as nominal pipe size - NPS, or "Nominal Pipe Size". The metric equivalent is called DN or "diametre nominel". The metric designations conform to International Standards Organization (ISO) usage and apply to all plumbing, natural gas, heating oil, and miscellaneous piping used in buildings. The use of NPS does not conform to American Standard pipe designations where the term NPS means "National Pipe Thread Straight".
Diameter Nominal
DN
(mm)Nominal Pipe Size
NPS
(inches)6 1/8 8 1/4 10 3/8 15 1/2 20 3/4 25 1 32 1 1/4 40 1 1/2 50 2 65 2 1/2 80 3 100 4 150 6 200 8 250 10 300 12 350 14 400 16 450 18 500 20 550 22 600 24 650 26 700 28 750 30 800 32 900 36 1000 40 1050 42 1100 44 1200 48 1300 52 1400 56 1500 60 1600 64 1700 68 1800 72 1900 76 2000 80 2200 88
