Thread: Article: check valve in boiler output
    You can view the page at
  3. I think use of check valve here is to avoid any condensate flow back to boiler. Just imagine when you get condensate hammering in main header. What can you do to avoid back flow of condensate (during condensate hammering, its like bullet) ??You must use check valve even if any code dont demand. will give u more info
    its impossible, because all condensate will remove after trap and in trap set we have check valve.
    this is not for condensate return,
  1. Check Valve : API 6D vs API 598
    By h9.hanin in forum Pipeline And Fluid Flow
    Last Post: 11-27-2013, 11:52 AM
  2. check valve in boiler output
    By tobbe in forum Pipeline And Fluid Flow
    Last Post: 07-24-2011, 11:22 AM
  3. Replies: 1
    Last Post: 07-03-2011, 08:38 PM
  4. Pressure relief valve / safety valve in steam line of boiler
    By nandu6630 in forum Pipeline And Fluid Flow
    Last Post: 06-27-2011, 01:05 AM
  5. Article: Transformer output voltage
    By cytech in forum Home Articles
    Last Post: 05-19-2011, 04:12 PM
