Page 1 of 2 1 2 LastLast
Results 1 to 12 of 22
Thread: AC VARIABLE FREQUENCY DRIVES training course download
    Variable Frequency Drives (also known by other names such as Variable Speed Drives, Inverter Drives, Frequency Drives, Adjustable speed drives) are growing in importance every day as you see them being increasingly used in all kinds of places, not just manufacturing plants and industries, but also in office buildings, warehouses and other commercial places. The reason is easy. Variable Frequency Drives are the best thing that ever happened to the ac induction motor, as you can now control these motors in a variety of ways, which were not at all possible earlier.
    However, the information that is available on how to use these drives is not very easily available. Of course there ARE several sources of information, but are problematic. Why? Read on below:
    You have seen how detailed and comprehensive the ebook is. So what are you waiting for? Download the FREE PREVIEW of the ebook, so that you know what you're getting. The FREE PREVIEW allows you to browse through the ENTIRE BOOK for a limited time- so you have nothing to lose!
    BASIC CONCEPTS
    Introduction
    VFDs, VSDs, ASDs, VVVF Converters, Inverters
    AC Motors
    An ac induction motor
    Speed Control of ac induction motors
    Power, Speed and Torque
    Torque
    Locked Rotor Torque
    Motor characteristics and types
    Design A motor
    Design B motor
    Design C motor
    Design D motor
    Design E motor
    Which type is best for my application?
    Load torque characteristics for different kind of loads
    Classification of loads
    Constant Torque loads
    Variable Torque loads
    Constant Power loads
    Four Quadrant Operation
    Overview of AC motor controls
    DOL starter (Direct On Line starter)/Across the line starter
    Star (Wye) and Delta connections
    Control with a VFD
    Inverter Duty Motors
    Advantages of using a VFD for control of motors
    Speed Regulation
    Better Power Factor
    Soft Starting
    Flexibility in input power
    Precision Controls for torque and speed
    Energy Saving
    Replacement of control valves in process plants
    Built in PID controls
    Communication
    Possibility of replacing DC drives with AC VFDs
    Disadvantages of VFDs
    Harmonics
    Cannot be used with all motors
    Distance limitations
    Noise
    Industrial applications of VFDs
    INSIDE A VFD
    Introduction
    Inside a VFD
    Overall design
    Rectifier Block
    DC Link block
    Inverter block
    Controller block
    VFD parts & VFD components
    VFD Components
    Diode
    Diode Curve
    Switching frequency of diodes
    Rectifier Circuits
    Half wave rectifier
    Full wave rectifier (Bridge rectifier)
    Three phase bridge rectifiers
    Thyristors (Silicon Controlled Rectifiers-SCRs)
    Firing angle
    Three phase rectifier using thyristors
    DC link block
    Soft Charge Circuit
    Inverter Block
    Transistor (BJT)
    Working model of a transistor
    Transistor as an amplifier
    Transistor as a switch
    MOSFET
    IGBT
    Pulse Width Modulation
    How does Pulse Width Modulation work?
    Changing the amplitude of the output sinusoidal waveform
    Changing the frequency of the output sinusoidal waveform
    Noise effects of PWM inverters
    VFD FUNCTIONS
    Starting/Stopping of the motor
    Acceleration/Deceleration
    Ramping
    Speed Limits
    Speed Changing
    a) Using the digital inputs
    b) Using a potentiometer
    c) Using the analog input signal
    d) Using Digital Communication
    Forward/Reverse operation
    Motor Thermal Overload Protection
    Slip Compensation
    Control schemes in VFDs
    Open Loop controls in VFDs
    Closed loop control with VFDs
    V/f Control
    Vector Control
    What is the "vector" in vector control?
    Sensorless vector control
    Flux Vector control (Closed loop)
    Shaft encoders
    Absolute encoders
    Incremental encoders
    Difference between absolute encoder and incremental encoder
    Closed Loop Flux Vector Control
    Field Oriented Control (FOC)
    Comparison between V/f drives and Vector Control drives.
    PID Control
    Anti-windmill protection and Flying Start
    Flying Start-Catching up with the motor at power on
    Skip Frequencies
    Torque Control
    Direct Torque Control
    How does DTC work?
    Advantages of DTC
    Disadvantages of DTC
    Motoring and regeneration
    Braking Resistor
    Dynamic Braking
    Line regenerative braking
    DC injection braking
    Motor Overflux braking
    ENERGY SAVINGS USING VFDs
    Types of Loads
    Pumps, Fans and Blowers
    Traditional flow control
    Control of Centrifugal Pumps
    Affinity Laws of Centrifugal Pumps
    Centrifugal Pump basics
    Pump Characteristic Curve
    System Curve
    Energy savings with fans and blowers
    Other energy savings due to VFDs
    Power Factor improvement
    Reduction in demand charges
    Shorter Duty Cycles
    SPECIFYING, SELECTING AND INSTALLING VFDs
    Flowchart
    Load considerations
    Evaluate VFD benefits versus traditional motor controls
    VFD features for maximum benefit
    Derating of VFDs
    Temperature Derating
    Altitude Derating
    Overload Capacity
    Harmonics due to VFD installations
    What are Harmonics?
    Total Harmonic Distortion
    Problems due to harmonics
    What could be the PCC? Says who?
    Measurement of harmonics
    Harmonics in PWM type drives
    Mitigation of harmonics
    Supply voltage
    Number of starts
    Fuse Disconnects
    Bypass circuit
    Installation inside a panel or other enclosure
    Earthing
    Maximum Cable length from VFD to the motor
    IGBT switching
    Standing wave & Reflected wave phenomenon
    Voltage drop
    Long cable length solutions
    Multiple inverters in the same VFD
    USING VFDS WITH DCS/PLC SYSTEMS
    VFDs used in a process plant
    Detailed Implementation of the above
    Digital Communications
    Need for digital communications
    Functions of a typical digital network
    Profibus
    Modbus
    Safety Aspects
    Summary & Conclusion
  3. thanks but the link not working
  5. link not working
  6. xxxx
  7. post with a good link.
  9. link not working
    link not working
  11. Confirm, link does not working.Please, share it again, on different server.
  12. Re: AC VARIABLE FREQUENCY DRIVES training course download
    Plesase update Download Link
  13. Re: AC VARIABLE FREQUENCY DRIVES training course download
    Quote Originally Posted by mdtrivedi View Post
    Please reload it please or update the link in different server, please..
  14. #11
    Here are some links to excellent training materials on AC variable frequency drives. Just copy and paste the links in your browser for a quick download.
    NEMA Application Guide for AC Adjustable Speed Drives
    94c0e3eb.theseforums.com (copy and paste this URL into your browser)
    ABB Guide to Variable Speed Drives
    5e93cad1.theseforums.com
    The quick guide to AC variable speed drives (small charge in some countries - not free)
    7850c4f8.theseforums.com
    919d34f2.theseforums.com
    Variable Frequency Drives Efficiency Guide
    f4d7509f.filesonthe.net
    VFD Application Guide
    63b0956d.filesonthe.net
  16. #12
    thank you for the links
  1. Variable frequency drives (VFD/VSD) course or training ppt
    By sghuge in forum Instrumentation & Control
    Last Post: 07-03-2013, 06:27 PM
  2. Help Needed: Top Drives
    By Firefox7 in forum Drilling And Workover
    Last Post: 02-26-2013, 09:22 AM
  3. ISA Motors and Drives: A Practical Technology Guide
    By bryandown in forum Instrumentation & Control
    Last Post: 12-04-2012, 08:07 PM
  4. Hazardous Area Instrumentation training course download
    By ali in forum Safety And Environment
    Last Post: 07-14-2011, 07:57 AM
  5. Replies: 0
    Last Post: 01-15-2009, 07:58 AM
