e-learning course on Gas Monitors
You probably already know just how important Gas Monitors training is and how difficult it can be to learn everything that you need to know.
Just as the correct selection and use of gas monitors can save you and your workplace from disaster, the wrong selection or improper working of gas monitors can actually cause a disaster!
A wrongly selected gas monitor will not only fail to work properly, but it will also lull you into a false sense of security.
Case 1: Explosion in Corrugated Paper Mill in Wisconsin
Workers who were doing hot work above a storage tank that had inflammable materials inside, did not do an "explosive gas test" before they started working, leading to an explosion and fire, causing multiple fatalities. The US Chemical Safety Board has now come out with a safety bulletin highlighting this incident.
This is the latest case out of a series of cases that have happened over the past few years. Most causes can ultimately be traced to a lack of training to design personnel, safety personnel and workers about hazardous gases and the methods to detect them and prevent disasters, by using proper gas monitors.
Comprehensive
covers all aspects of Gas Monitors including types of gases, what all the jargon about TWA, STEL, etc means, principles of working of different kinds of sensors, selection, installation, calibration and maintenance
Cost Effective
costs a fraction of what it would take to enroll in a classroom course or seminar ( if you can find one, that is).
Easy To Understand
Full of rich graphics, real life plant videos and Flash based animations, unlike those boring books. Makes learning more of fun and less of a chore.
Vendor Neutral
The course is not based upon some gas monitor manufacturer's product line, it is a completely neutral, technology oriented course. So you get a true understanding of the technology behind gas monitoring-so essential if you want to evaluate different vendors.
Stays on your computer (Download version)
No need to get refresher training. The course resides on your computer - refer to it for as long as you like, whenever you want.
Accessible from anywhere (Online LMS version)
The online version is hosted on our own Learning Management System (LMS) and can be accessed from any computer with an Internet connection. Just uses a web browser. Ideal for corporations who wish to train large numbers of employees. Get all reports related to login times, test scores, etc at no additional charge. Ideal for meeting statutory compliance documentation.
Customizable
No need to create your own training course. This course covers everything that you need to know. If you wish to customize the course, we can do it for you! Just tell us what you need to change.
Get Certified
If you pass our online test after you take the course, you can earn a certificate too! At no additional cost!!
Why an e-learning course on Gas Monitors?
Gas Monitors are used in a wide variety of applications ranging from ranging from semiconductor manufacturing, wastewater treatment plants, power plants, chemical plants and oil & gas production facilities. Millions of gas monitors work everyday in these places, to warn personnel working in these places about potential disasters like leaking gases, explosive vapors or toxic emissions.
Unfortunately, up to now, there was no single classroom training course, or e-learning course which could provide sufficient information, in an easy to understand way, how to select gas monitors, install them correctly and maintain and calibrate them, so that they continue to work well.
If you are an Instrumentation & Controls professional, automation expert, safety professional or an operations and maintenance engineer, working in any of these places, you would be certainly interested in knowing more about these instruments and to know how they can help you prevent disasters.
Ditto if you are a design engineer involved in the design of facilities that may have hazardous and/or toxic gases, or a government regulator, or an independent consultant working on projects. You will find this course extremely useful.
Even vendors of gas detection equipment and system integrators who use gas monitors as part of their equipment (like gas turbines), have successfully used this course to train their own staff and customers.
Of course you can come across many "free" training courses, but they are often sponsored by some vendors, with hidden agendas, who wish to promote their own products and technology.
You, as an intelligent user, are entitled to an unbiased, factual training course, made by professionals who have extensive experience as users (rather than vendors).
So here's what this course has to offer….read on below.
Until now, you had to spend years studying books, reports and other training materials. And if you're like most people, you'd just end up more confused than you were before you started the training.
There are FOUR learning units in this course. Each Learning Unit consists of several lessons. Each lesson contains several pages of text, graphics and animated videos for EASY learning.
Gas Monitors (also known as Gas detectors) keep workplaces and people safe.
Do you know how they work?
How to select them and maintain them so that they continue to enhance safety in your workplace?
LEARNING UNIT ONE-Gas Monitor Fundamentals
LESSON ONE- Introduction to Gas Monitors
Introduction to the course
Introduction to gas monitors
What is a gas monitor?
Why use a gas monitor?
History of gas monitors
Where are gas monitors used?--Oil refining
Where are gas monitors used?-Storage Tanks
Where are gas monitors used? - Electronics & semiconductor plants
Where are gas monitors used?-Oil Production
A typical gas monitor
A personal gas monitor
A personal gas monitor-2
A portable gas monitor
A fixed gas monitor
Summary of Lesson One
LESSON TWO-Basic Concepts
Lesson Outline
Fire Triangle
Lower Explosive Limit & Upper Explosive Limit
Lower Explosive Limit & Upper Explosive Limit-2
Flash Point
Accuracy
Accuracy & Inaccuracy
Accuracy of a Gas Monitor
Calibration
Calibration of Gas Monitors
Linearity
Linearity-2
Repeatability
Repeatability & Accuracy
An exercise in repeatability
Summary of Lesson Two
LESSON THREE-Explosive & Toxic Gases
Lesson Outline
Explosive gases & Toxic Gases
Regulatory & Standards Bodies
Terminology--Explosive Gases
Terminology--Toxic Gases
TWA (Time Weighted Average)
More on TWA (Time Weighted Average)
STEL (Short Term Exposure Limit)
IDLH & Ceiling Limit
REL, PEL & TLV ---What do they mean?
REL, PEL & TLV ---Some values
A graph of TWA. STEL and Ceiling Limits
Conclusion
LEARNING UNIT TWO-Types of Gas Monitors
LESSON ONE-Catalytic Combustion Type
Learning Unit Outline
Introduction to Catalytic Combustion
Catalytic Combustion sensor--How it works 1
Catalytic Combustion sensor -How it works 2
Catalytic Combustion sensor -How it works 3
Catalytic Combustion sensor -construction
Catalytic Combustion sensor -characteristics
Catalytic Combustion sensor -Advantages & Disadvantages
LESSON TWO-Electrochemical Type
Introduction to Electrochemical sensors
Electrochemical sensors-Principles 1
Electrochemical sensors-Principles 2
Electrochemical sensors-Actual Operation
Electrochemical sensors-Construction 1
Electrochemical sensors-Construction 2
Electrochemical sensors-Other characteristics
Electrochemical sensors-Interference
Electrochemical sensors-Advantages & Disadvantages
LESSON THREE-Semiconductor type
Semiconductor sensors-Introduction 1
Semiconductor sensors-Introduction 2
Semiconductor sensors-Working 1
Semiconductor sensors-Working 2
Semiconductor sensors-Working 3
Semiconductor sensors-Advantages & Disadvantages
LESSON FOUR-Infra Red Type
Infra Red sensors-How are they different?
What are Waves?
Basics of waves
The electromagnetic spectrum 1
The Electromagnetic Spectrum 2
Infra Red sensors-Basic Concepts
Transmittance & Absorbance
Infra Red sensors-Beer Lambert Law 1
Infra Red sensors-Beer Lambert Law-2
Infra Red sensors-- Absorption Pattern of Methane
Infra Red monitors
Infra Red monitors-Dispersive
Infra Red monitors-Non dispersive
Infra Red monitors-Point type and Open Path
Infra Red monitors- Open Path
Infra Red gas monitors-Open Path Concepts
Infra Red gas monitors-Point type and Open Path
Infra Red gas monitors-Advantages & Disadvantages
LESSON FIVE-PID Type
Photo Ionization Detectors-Introduction
Photo Ionization Detectors-Principle of Operation
Photo Ionization Detectors-A typical instrument
Photo Ionization Detectors-The UV Lamp
Photo Ionization Detectors-Kinds of lamps 1
Photo Ionization Detectors-Kinds of lamps 2
Photo Ionization Detectors-Lamp selection
Photo Ionization Detectors- Correction Factors
Photo Ionization Detectors-VOC monitoring
Photo Ionization Detectors-Alarm Limits
Photo Ionization Detectors-Advantages & Disadvantages
LEARNING UNIT THREE-Gas Monitoring Systems
LESSON ONE-Dedicated systems
Dedicated Systems-Introduction
Dedicated Systems-The channel card
Dedicated Systems-Architecture 1
Dedicated Systems-Architecture 2
Dedicated Systems-Advantages and Disadvantages
Dedicated Systems
LESSON TWO-Open Systems
Open Systems-Introduction
Open Systems-Integrated DCS & Gas Monitoring system
Open Systems-Other possibilities
Open Systems- Advantages & Disadvantages
Open Systems
LEARNING UNIT FOUR-Installation, Calibration & Maintenance
LESSON ONE-Planning & Installation of gas monitors
Planning of gas monitoring systems 1
Planning of gas monitoring systems 2
Planning of gas monitoring systems-placement
Relative weights of different gases
Placement of the gas monitors
Installation of gas monitors--A simulation exercise
LESSON TWO-Calibration & Testing
Preparation for Calibration
Calibration of Gas Monitors-example 1
Calibration of Gas Monitors-example 2
Calibration of Gas Monitors-example 3
Calibration of Gas Monitors-example 4
LEL values of Explosive Gases
Correction Factors--Catalytic Combustion monitors
Calibration Factors--PID instruments
Calibration -Tips for a better Gas Monitor performance
Calibration
LESSON THREE-Maintenance
Maintenance of Gas Monitors-Introduction
Maintenance of Gas Monitors-example 1
Maintenance of Gas Monitors-example 2
Thank You
SELF ASSESSMENT TEST
