A comprehensive e-learning course (with free online exam & Certification)on
Safety Instrumented Systems
Covering more than any other course available today at a price that is less than any other!
Dear Friend,
You are here, reading this page, because you are well aware of the role of Safety Instrumented Systems (SIS), in protection of assets and people. In recent years, there have been extensive studies on the best ways of making our process plants safer and the conclusion is that by just doing one thing right, which is -increasing the reliability of the Instrumentation and Control systems in a plant, can make these plants much safer.
On the other hand, negligence in respect of Safety Instrumented Systems (SIS) can be really disastrous, literally. Look at just a few recent cases below.
What are Safety Instrumented Systems?
Basic Ideas about SIS
Functional Safety
Instrumented Systems & Safety Instrumented Systems
BPCS
BPCS and SIS
Safety Instrumented Function
Safety Instrumented Function-2
Safety Instrumented Function-3
Emergency Shutdown Systems
Need for a separate SIS
Simulation exercise
Learnings from the exercise
Typical architecture
Integrated BPCS & SIS
Integrated BPCS & SIS-2
Examples
Differences between BPCS & SIS
MODULE 2-Hazards, Risks & their analysis
Hazards & Risks
Types of hazards- Fire & Explosions
Types of hazards-Toxic Material
The Safety Lifecycle
Steps in analysis
Preliminary Hazard Analysis
HAZOP
HAZAN
Consequence Analysis
Risk
Risk graph
Risk Reduction
Risk Reduction-2
The ALARP principle
Risk Reduction in process plants
Risk Reduction explained
Risk reduction using an SIF
Layers of Protection
Layers of Protection in the process industries
Preventive & Mitigative layers
Safety Requirement Specification
Safety Requirement Specification-2
Diversity
MODULE 3-Failures & Reliability
Failures
Types of failures
Types of failures-2
Types of failures-3
Dangerous & Safe failures
Safe Failure Fraction
SFF Pie Chart
Proof Test Interval
Diagnostic Coverage
Common Cause Failures
Common Cause Failures-2
CCF Example
Diversity
Reliability
Failure Rate
MTTF
MTTR
MTBF
Failure Data
Software Reliability & fault injection
Reliability Block Diagrams
Reliability Block Diagrams-2
Reliability Block Diagrams-3
Redundancy and Reliability
Fault Tree Analysis
Fault Tree Analysis Example- 1
FTA and RBD
Fault Tree Analysis Example-2
Fault Tree Analysis-Probabilities
Event Trees
Event Tree Components
Event Tree Analysis Example
Fail-Safe and Fail Danger modes
FMEA
FMEDA
FMEDA report
How to use the FMEDA report
Redundancy
Redundancy and Voting
Voting Systems 1oo1
Voting Systems 1oo2
Voting Systems 1oo2D
Voting Systems 2oo2
Voting Systems 2oo3
Spurious Trips
Concept of Demand
Low Demand & High Demand
Demand in a plant
PFD
MODULE 4-Safety Integrity Level
Introduction to Safety Integrity Level
What SIL is not
Is SIL applicable to me?
SIL 1 to SIL 4
SIL for Demand Mode
SIL for Demand Mode-Example
SIL for Continuous/High Demand Mode
The SIL process
Common SIL questions
Common SIL questions-2
Target SIL-Qualitative & Quantitative methods
Risk Reduction Factor-1
Risk Reduction Factor-2
Safety Availability and PFDavg
SIL calculation Example
SIL calculation Example (contd)
SIL Calculation example-(modification)
SIL Calculation example-additional layers
SIL Calculation example-caution
Consequence Only Method
Hazard Matrix Method
Hazard Matrix Method- (contd)
Hazard Matrix Method-Example
Risk Parameter Graph-1
Risk Parameter Graph-2
Risk Parameter Graph-3
LOPA method
Conducting a LOPA
LOPA method
LOPA Example
LOPA Example contd
LOPA Example contd 2
LOPA Example contd 3
SIL verification basics
PFD of simple loop
SIF design process
SIL verification
Architectural Constraints
Architectural Constraints IEC 61508
Hardware Fault Tolerance-IEC61508
Architectural Constraints-Example
Hardware Fault Tolerance (contd)
Hardware Fault Tolerance-IEC61511
SIL verification methods
Simplified Equations
Use of Simplified Equations-Example
Markov Modeling-1
Markov Modeling-2
Markov Modeling-3
Markov Modeling-4
SIL verification example
SIL verification example-2
MODULE 5-SIS Standards
Introduction to Standards in SIS
AK 1 to AK 8
IEC Standards
IEC 61508
IEC 61508-Safety Life Cycle
IEC 61511-Basics
Relationship between IEC 61508 & IEC 61511
ISA S84 Background
Practical applications
What standards apply to me?
MODULE 6- SIS in practice
Components of the Safety Loop
Types of logic Solvers
Hardwired logic solvers-Trip amplifiers
Hardwired logic solvers-Gates
Safety Relays-Electromechanical
Safety Relays-Electromechanical-2
Safety Relays-Electromechanical-3
Safety Relays-Electromechanical-4
Safety Relays-Electronic
Safety Relays-Electronic-2
Safety Relays-Electronic-3
Programmable Logic Solvers
Safety PLCs & General Purpose PLCs
Fault Diagnostics
Safety PLCs- Inputs
Safety PLCs-Processors
Safety PLCs- Outputs
Safety PLCs-Software
Safety PLCs-Software-2
Safety PLCs-Software-Design
Safety PLCs-Voting architecture
Safety PLCs-TMR
Safety PLCs-QMR
Safety PLCs-Interface to BPCS
Safety Networks-1
Safety Networks-2
HIPPS
MODULE 7-SIS Testing & Maintenance
Need for testing
Testing-Example
Breakup of failures
Testing the components of a SIS
Testing Sensors & Transmitters
Testing Logic Solvers
Testing valves
Valve Testing-Bypass method
Partial Stroke Testing
Partial Stroke Testing-ISA method
Valve Testing- Mechanical Stoppers
Valve Testing-Smart Positioner method
PST-Advantages & Disadvantages
Self Assessment Test
COURSE TABLE OF CONTENTS
You have seen how detailed and comprehensive this course is, as compared to any other course anywhere. So what are you waiting for?
Download it now!
100 % satisfaction guaranteed.
If you find that this course is not worth the price or it does not work for you for any reason within a period of 30 days, then we will refund you your full money back!
Note:
1. For companies and other organizations who wish to tweak this course, we also offer CUSTOMIZATION options. Please send your query to sales@abhisam.com
2. We can also offer a HOSTED option. This allows learners to take the entire course ONLINE without DOWNLOADING any software at all. Reports of learner login times, scores can be provided.
Includes how to assess and verify Safety Integrity Level (SIL)
Caribbean Petroleum, Puerto Rico, 2009
A massive fire and explosion sent huge flames and smoke plumes into the air at the Caribbean Petroleum Corporation near San Juan, Puerto Rico. The resulting pressure wave damaged surrounding buildings and impacted moving vehicles. Preliminary cause found, was non working of the overfill protection system (part of the Safety Instrumented System).
Petrolia, Pennsylvania, USA, 2008
Thousands of residents of surrounding areas had to be evacuated to safer places when there was a release of large quantities of Oleum (fuming Sulfuric acid), from a chemical plant. The root cause was determined to be non implementation of a proper Safety Instrumented System.
Danvers, Massachusetts, USA, 2006
Massive explosion at an ink processing plant causes destruction of plant as well as surrounding homes, injuring many residents of surrounding areas. Cause? Lack of safety interlocks and automatic shutdown systems (in other words a Safety Instrumented System) in the plant.
Morgantown, North Carolina,USA, 2006
Explosion at a polymer manufacturing plant led to total damage of the facility, with a human fatality and several injuries. Investigations found out that a lack of process safety standards and non implementation of automatic interlock systems (in other words, Safety Instrumented Systems) as the root causes of the disaster.
Buncefield, UK, 2005
The Buncefield industrial disaster was one of the biggest disasters to strike the chemical and petrochemical industry in Europe in recent years. The blasts that occurred were so loud, they were heard as far away as France! (Buncefield is in the UK) The root cause was found out to be a probable malfunctioning Safety Instrumented System in one of the plants on the site.
The list goes on and on.....
Of course, you agree, that Safety Instrumented Systems are essential and are operational in many plants and facilities around the globe. But mere operation and existence of such a system, does not ensure, that it will always work as designed , is it not?
You need to know it in depth, to make it work for you.
To make it work for you, you need to know these systems thoroughly ( I mean not from a programming point of view but from a users point of view). You need to get trained in all the concepts and ideas of Safety Instrumented Systems. Note that here, when we refer to Safety Instrumented Systems(SIS), we also include Emergency Shutdown Systems (ESD), Safety Shutdown Systems, High Integrity Pressure Protection Systems (HIPPS) and all similar systems that are used to ensure the safe operation of plant and machinery, using instruments, electrical and pneumatic/hydraulic devices.
However, the jargon associated with these sophisticated process control systems is so put-offing and even confusing, that even experienced professionals cringe at the mention of Triple Modular Redundant, 2oo3 voting, SIL 3 or IEC 61508.
Does it really have to be this way?
No! Not really.
You can get this e-learning course on Safety Instrumented Systems(SIS) and learn all about these systems, in the comfort of your home or office.
Just download this Safety Instrumented Systems e-learning course today and for a fraction of the price that you would otherwise pay for a classroom training course, learn everything that you wanted to know about SIS (but didn't know whom to ask).
Of course, you could always pass this up and decide to go for that seminar or classroom training, whenever that is offered , or buy a book on this topic,
but,
remember that
a) this early bird price will not last for long
b) you will forget all about this, till the time comes for you to explain to somebody higher up, as to why you installed the 2oo3 Safety Logic Solver instead of the alternate 1oo2 Logic Solver , OR (God forbid)-you have to explain to a government inspector why you felt that SIL 1 was adequate for your Safety Instrumented function instead of a SIL 3 that he felt should have been required.
c) you will , once again, be conned into buying a SIL 3 transmitter from that smooth talking vendor (there is no such thing as a SIL 3 transmitter BTW-find out why in the course)
d) You forget about this e-learning course completely. Then you enroll yourself in an expensive $ 2500 classroom course, travel halfway around the globe to attend it, spend some more of your undernourished training budget on it and then forget whatever you learned when the time comes to finally apply the concepts learned in your work.
e) You decide to skip this offer and opt to buy a book (or books) on this topic. However, there are a couple of problems. The first is that not a single book is available on the market, that covers all the topics that you need to know. On the other hand, there are a lot of things in every book, that you can safely skip, without missing anything. Thus, if you wish to source your knowledge of Safety Instrumented Systems from books, you will have to buy not one but several. They also cost a pretty penny (are not cheap at all). The cost of just two of them will be more than the price of this course
So, why don't you simply download this first of its kind training course on Safety Instrumented Systems and
a) Be assured that you have the best course on Safety Instrumented Systems in an e-learning format.
b) Have access always, to the entire course (it will reside silently on your computer 24/7), for as long as you retain your computer. There is no recurring license fee. This means once you buy a license, you can access it for as long as you wish, on the same computer.
c) Get a comprehensive course that has several Flash based animations and rich graphics, explained in a very simple to understand way, with accompanying text, that will remove all the "complexity" that is normally associated with this subject.
