Please can anyone get API RP 550 across to me.
Thank you
Thank you
This manual was replaced by Replaced by:
API RP 551
API RP 552
API RP 553
API RP 554
I Have this API STANDARDS but are to big to send by this forum, i think.
API API 510 Pressure Vessel Inspection Code In-Service Inspection, Rating, Repair, and Alteration - Ninth Edition.pdf
API API 579-1 Fitness-for-Service - Second Edition.pdf
API API RP 581 Risk-Based Inspection Technology - Second Edition.pdf
API RP 555 Process Analyzers - Second Edition.pdf
API STD 5T1 ADD 1 Standard on Imperfection Terminology - Tenth Edition.pdf
API STD 5T1 Standard on Imperfection Terminology - Tenth Edition; Formerly Bull 5T1.pdf
API STD 11D3 Progressing Cavity Pump Systems for Artificial Lift—Surface-drive Systems - First Edition.pdf
API STD 520 PT I Sizing, Selection, and Installation of Pressure-relieving Devices in Refineries Part I - Sizing and Selection - EIGHTH EDITION.pdf
API STD 521 Pressure-relieving and Depressuring Systems - Fifth Edition Incorporates Errata 6 2007 and Addendum 5 2008.pdf
API STD 526 Flanged Steel Pressure Relief Valves - Fifth Edition.pdf
API STD 527 Seat Tightness of Pressure Relief Valves.pdf
API STD 530 Calculation of Heater-tube Thickness in Petroleum Refineries - Sixth Edition.pdf
API STD 537 Flare Details for General Refinery and Petrochemical Service - First Edition.pdf
API STD 541 Form-Wound Squirrel-Cage Induction Motors - 500 Horsepower and Larger - Fourth Edition.pdf
API STD 546 Brushless Synchronous Machines - 500 kVA and Larger - Third Edition.pdf
API STD 547 General-purpose Form-wound Squirrel Cage Induction Motors 250 Horsepower and Larger - First Edition.pdf
API STD 560 Fired Heaters for General Refinery Services - Fourth Edition.pdf
API STD 594 Check Valves Flanged, Lug, Wafer and Butt-welding - Sixth Edition.pdf
API STD 598 Valve Inspection and Testing - Eighth Edition.pdf
API STD 599 Metal Plug Valves—Flanged, Threaded and Welding Ends - SIXTH EDITION.pdf
API STD 600 Bolted Bonnet Steel Gate Valves for Petroleum and Natural Gas Industries - Eleventh Edition ISO 10434 2001 Adoption.pdf
API STD 602 Steel Gate, Globe and Check Valves for Sizes DN 100 and Smaller for the Petroleum and Natural Gas Industries - Eighth Edition ISO 15761 Adoption.pdf
API STD 603 Corrosion-resistant, Bolted Bonnet Gate Valves—Flanged and Butt-welding Ends - SEVENTH EDITION.pdf
API STD 607 Fire Test for Soft-seated Quarter-turn Valves - Fifth Edition ISO 10497-5 2004 Adoption Errata November 2008.pdf
API STD 608 Metal Ball Valves - Flanged, Threaded and Welding Ends - FOURTH EDITION EFFECTIVE DATE JUNE 2009.pdf
API STD 609 Butterfly Valves Double Flanged, Lug- and Wafer-Type - Sixth Edition.pdf
API STD 610 Centrifugal Pumps for Petroleum, Petrochemical and Natural Gas Industries - Tenth Edition; ISO 13709 Adoption.pdf
API STD 611 General-purpose Steam Turbines for Petroleum, Chemical, and Gas Industry Services - Fifth Edition.pdf
API STD 612 Petroleum, Petrochemical and Natural Gas Industries - Steam Turbines - Special-Purpose Applications - Sixth Edition.pdf
API STD 613 Special Purpose Gear Units for Petroleum, Chemical, and Gas Industry Services - Fifth Edition Errata December 5, 2005.pdf
API STD 614 Lubrication, Shaft-sealing and Oil-control Systems and Auxiliaries - Fifth Edition.pdf
API STD 616 Gas Turbines for Petroleum, Chemical, and Gas Industry Services - Fourth Edition.pdf
API STD 617 Axial and Centrifugal Compressors and Expander-Compressors for Petroleum, Chemical and Gas Industry Services - Seventh Edition Errata June 1, 2003.pdf
API STD 618 Reciprocating Compressors for Petroleum, Chemical, and Gas Industry Services - Fifth Edition.pdf
API STD 619 Rotary-Type Positive-Displacement Compressors for Petroleum, Petrochemical, and Natural Gas Industries - Fourth Edition.pdf
API STD 620 Design and Construction of Large, Welded, Low-Pressure Storage Tanks - Eleventh Edition.pdf
API STD 650 Welded Tanks for Oil Storage - Eleventh Edition Incorporating Addendum 1 November 2008.pdf
API STD 653 Tank Inspection, Repair, Alteration, and Reconstruction - Third Edition.pdf
API STD 660 Shell-and-Tube Heat Exchangers - Eighth Edition.pdf
API STD 661 Air-Cooled Heat Exchangers for General Refinery Service - Sixth Edition; ISO 13706-1.pdf
API STD 662 PART 1 Plate Heat Exchangers for General Refinery Services - Part 1 - Plate-and-Frame Heat Exchangers - First Edition.pdf
API STD 662 PART 2 Plate Heat Exchangers for General Refinery Services - Part 2 - Brazed Aluminum Plate-fin Heat Exchangers - First Edition.pdf
API STD 670 Machinery Protection Systems - Fourth Edition.pdf
API STD 671 Special-Purpose Couplings for Petroleum, Chemical, and Gas Industry Services - Fourth Edition.pdf
API STD 672 Packaged, Integrally Geared Centrifugal Air Compressors for Petroleum, Chemical, and Gas Industry.pdf
API STD 673 Centrifugal Fans for Petroleum, Chemical and Gas for Industry Services.pdf
API STD 674 Positive Displacement Pumps - Reciprocating.pdf
API STD 675 Positive Displacement Pumps - Controlled Volume.pdf
API STD 676 Positive Displacement Pumps - Rotary.pdf
API STD 677 General-Purpose Gear Units for Petroleum, Chemical and Gas Industry Services - Third Edition.pdf
API STD 681 Liquid Ring Vacuum Pumps and Compressors for Petroleum, Chemical, and Gas Industry Services - First Edition.pdf
API STD 570.pdf
API RP 551.pdf
API RP 552.pdf
API RP 553.pdf
API RP 554.pdf
Hi metroplex,
Please you can just post API RP 551,552,554 AND API TP555.
And give me the links. Thanks.
Hi,
Please review following threads to your requirement. it is already there.
Please, metroplex, I need API STD 620 and API STD 650
i also need API STD 620 11th and API STD 650 ,thanks
Hi!
I need Api Std 537, please could you send me by mail at or give me the download link?
Thanks a lot
EDIT
I found it
Can anybody help me please?
I need the API RP7G 1998, API SPEC7 2002 and “Horizontal Technology Manual”, Maurer Engineering Inc., Houston, Texas (1996)
I've only API RP7G (1998)
Thank you so much easyrap![]()
No problem
I've also API SPEC7 1998 (or 1999, I don't remember now), if you want I upload it
Ok! easyrap, I want API spec7, upload it please
