Page 1 of 2 1 2 LastLast
Results 1 to 12 of 13
Thread: Iec 61064
  1. Iec 61064
    Salam
    I need this norme IEC 61064: Acceptance Tests for Steam Turbine Speed Control Systems
    and standards any regulation which deals with the steam turbine and the frequency
    thank you
    baraka llah fikom
    Sep 2008
    Here only- EGPET
    Blog Entries
    5
    Enjoy
  5. thank you su much
  6. thank you
    I also sought the standard for steam turbine
    IEC 60045-1
    IEC 60953-1
    IEC 60953-2
    IEC 60953-3
    IEC 61063
    IEC 61064
    IEC/TS 61370
    baraka llah fikom
    I have only one of those...
    IEC 60953-1-1990 Part 1 Method A - High accuracy for large condensing steam turbines.pdf 9.936 MB
  9. thank you Nabilia
    Re: Iec 61064
    link is dead, Please send again IEC61064.
    Regards/Raj
  11. Re: Iec 61064
    Salam,
    The new link Here
    Re: Iec 61064
    Dear Sir
    If you have the following standard, please share:
    1. IEC 61064 EN - Acceptance Tests for Steam Turbine Speed Control Systems-First Edition
    3. NEMA Standard 46-112, 1946 - Speed-Governing and Pressure Control of Steam Turbine Generator Units.
    4. PTC20.1 - 1977 (R1988) - Speed and Load-Governing Systems for Steam Turbine-Generator Units
    5. PTC20.2 - 1965 (R1986) - Over speed Trip Systems for Steam Turbine-Generator Units
    6. PTC20.3 - 1970 (R1986) - Pressure Control Systems Used on Steam Turbine Generator Units
    7. NEMA Standards Publication No. SM 23-1991 (R1997, R2002)- Steam Turbines for Mechanical Drive Service
    8. DIN 1943 Steam Turbines - Acceptance Tests
    9. BS EN 60953 - Rules for Steam Turbine Thermal Acceptance Test
    10. IEC 953 - Rules for Steam Turbine Thermal Acceptance Test
    11. NEMA SM 12-1967(R-1977)- Direct connected steam turbine synchronous generator units, air cooled.
    RKD
  13. Re: Iec 61064
    NEMA SM 23-1991
    [link Point to another website Only the registered members can access] asme ptc 20.1
    asme ptc 20.3
    [link Point to another website Only the registered members can access] iec 61064 is already posted above
  14. Re: Iec 61064
    Salam
    Thank you
    And i Add this norme IEC 60953-1-Part 1 Method A
  16. #12
    Re: Iec 61064
    thank you
  1. Iec 61064
    By saiddt in forum Mechanical Engineering
    Last Post: 06-16-2011, 05:04 PM
