Page 1 of 2 1 2 LastLast
Results 1 to 12 of 15
Thread: Welding Books
  1. Welding Books
    Welding Steels Without Hydrogen *****ing (06324G)
    [link Point to another website Only the registered members can access] A comprehensive guide to avoiding hydrogen *****ing which serves as an essential problem-solver for anyone involved in the welding of ferritic steels. The authors provide a lucid and thorough explanation of the theoretical background to the subject but the main emphasis throughout is firmly on practice.
    Contents
    Defining the problem
    - Hydrogen-induced *****ing in welds
    - Factors responsible for *****ing and their control
    - Detection and identification
    Guidance on safe welding procedures by graphical methods
    - Low hardenability steels
    - High hardenability steels
    - The choice of method
    - Joint simulation testing
    Selecting values for graphical presentation
    - Chemical composition
    - Carbon equivalent level
    - Precision of the CE formulae
    - Effects of sulphur
    - Welding dissimilar metals
    - Hydrogen potential of the consumable
    - Selection of carbon equivalent axis
    - Combined thickness of the joint
    - Heat input
    - Preheat and interpass temperature
    - Postheat
    - Fit-up
    - Misalignment
    - Multirun welds
    - Tack welds
    Welding procedures for different steel types
    - Mild steel
    - Carbon manganese steels
    - Lower carbon, lean alloy steels
    - Medium carbon and carbon-manganese steels
    - Alloy steels
    - High carbon, plain and alloy steels
    - Machinable grades of steel
    Removing hydrogen during welding and heat treatment
    - Construction of hydrogen removal curves
    - Simplification of weld joint geometry
    - Material thickness
    - Heat treatment temperature and choice of the valve for D
    - Choice of value for total original hydrogen level
    - Use of hydrogen removal curves in practice
  3. Welding Symbols on Drawings
    Weld symbols on drawings was originally published in 1982 based on BS 499 (British Standards Institution 1980), ISO 2553 (International Standards Organisation 1979) and ANSI/AWS A2.4 (American Welding Society-1979) standards. These standards have been through numerous revisions over the last few years; and the current standards are ISO 2553 1992, BSEN 22553 1995, and ANSI/AWS A2.4 1998. The American system of symbolisation is currently used by approximately half of the world’s industry. Most of the rest of the world use ISO. The British system was standardised in 1933 and the latest of five revisions was published in 1995 as BSEN 22553, which is identical to ISO 2553. For many years an ISO committee has been working on combining ISO and AWS to create a combined worldwide standard, but while discussions continue this could take many years to achieve.
    This contemporary book provides an up-to-date review on the application of ISO and AWS standards and a comparison between them. Many thousands of engineering drawings are currently in use, which have symbols and methods of representation from superseded standards. The current European and ISO standards and the American standard are substantially similar, but the ANSI/AWS standard includes some additional symbols and also symbols for non-destructive testing. Although symbols in the different standards are similar, the arrows showing locations of welds are different, these important differences are explained. ISO contains limited information on brazed or soldered joints these are covered in ANSI/AWS. Some examples of the application of welding symbols are also included.
    Contents
    Introduction
    The standards
    Scope
    Terminology
    The need to specify welds
    The advantages of symbols
    Welding symbols: butt/groove welds
    Welding symbols: fillet weld
    - Edge weld. Backing run or weld
    - Flare-V groove and bevel welds
    - Plug or slot weld
    Welding symbols: spot welds
    - Seam welds
    - Surfacing
    - Steep flanked butt welds
    Location of symbols 1: butt welds
    Location of symbols 2: fillet welds
    Supplementary symbols
    Dimensions 1: Butt/groove welds
    Dimensions 2: Fillet welds, transverse
    Dimensions 3: Fillet welds, longitudinal
    Spot and seam welds
    Stud welds
    Surfacing
    Process identification
    Nondestructive testing symbols, AWS
    Exercises in the use of symbols
    Terms and definitions for welding symbols
  5. Audel Welding Pocket Reference
    Featuring updated charts dealing with the most common situations welding workers face on the job , this comprehensive, pocket-sized reference is based on recommendations from working professionals and covers welding symbols and definitions, types of joints and welds, typical welding station configurations, oxygen cylinders, arc-welding charts, U.S metric measures, and more.
    1. Welding and Cutting Safety.
    2. Oxyacetylene Welding.
    3. Oxyacetylene Cutting.
    4. Shielded Metal Are Welding.
    5. Arc Welding and Cutting.
    6. Brazing and Braze Welding.
    7. Soldering.
    8. Identifying Metals.
    9. Cast Iron.
    10. Wrought Iron.
    11. Carbon Steels.
    12. Alloy Steels.
    13. Reactive and Refractory Metals.
    14. Galvanized Metals.
    15. Soft Metals Welding.
    16. Magnesium and Magnesium Alloys.
    17. Lead, Tin and Zinc.
    18. Hard Facing and Tool and Die Steels.
    19. Types of Joints.
    20. Welding Positions.
    21. Types of Welds.
    22. Weld Terminology.
    23. Welding Symbols.
    24. Tips for Producing Good Welds.
    Appendix A: SMAW Carbon Steel Electrodes.
    Appendix B: SMAW Stainless Steel Electrodes
    Appendix C: SMAW Aluminum Electrodes.
    Appendix D: Conversion Tables
  6. Surface Phenomena in Fusion Welding Processes
    The manufacturing industry currently employs a wide variety of welding processes. The main technological process applied in the production of weldments is fusion welding. Presenting the latest research on the topic, Surface phenomena in fusion welding processes is a cutting-edge and comprehensive book that details the various courses of action that occur during welding procedures.
    It explains established regularities that are useful in the development of processes; details the formation of defects, allowing for an understanding of the role of surface properties and surface phenomena during the formation of defects; and describes welding in space, elucidating the determination role of surface phenomena in that environment. The text also contains 217 figures, 29 tables, and 336 equations to provide the reader with a better understanding of the various processes.
    In the development of welding technologies, as well as welding consumables, it is essential to know and to take into account both the surface properties of the applied materials and the surface phenomena that affect the boundaries of contacting phases. Surface phenomena in fusion welding processes presents this knowledge in a thorough and accessible manner, making it the ideal reference for practical and scientific specialists in the fields of welding and metallurgy
  7. Welding Robots: Technology, System Issues and Application
    nufacturing to the production of niche products, welding is now one of the most widespread and successful applications of industrial robotics.
    Welding Robotics: Technology, System Issues and Application is a detailed overview of robotic welding at the beginning of the twenty-first century. The last few years-worth of evolution in robotic welding are described, illustrating their rapid innovations and featuring:
    Welding Technology;
    Sensors and Sensing Techniques;
    Industrial robotic welding systems; and
    Actual industrial application of modern-day robotic welding techniques.
    Containing worked examples and problems throughout the book, Welding Robotics: Technology, System Issues and Application will be an ideal guide for students of robotics and manufacturing engineering who wish to gain a full understanding of the latest robot welding technologies as well a useful reference for active researchers and those working in industry. The book signposts future developments and aims to give readers the information that they need to contribute to the next wave of development of a growing and important area of manufacturing technology
  9. Metallurgy of welding
    A new edition of a well established and respected textbook from an author who is a recognised authority in this field. Joining techniques are one of the key technologies in materials engineering and this book provides comprehensive coverage of the cubject. It is intended for undergraduate and graduate students of metallurgy, as well as those attending specialist welding courses.
    The text covers the metallurgical changes that take place during the welding process, the properties of welded joints, defects associated with welding and the behaviour of welded joints in service. There is a chapter devoted to joints between metals and ceramics, and on the use of structural adhesives. The various techniques used in microwelding and the joining of solid-state devices to printed circuit boards are briefly described.
    Contents
    Metallurgical presentation of the general welding processes and characteristics of the welding operation; Thermal and thermochemical study of welding; Introduction to the metallographical examination of welds; Formation of the fusion zone; Solidification of the weld metal; Solid phase transformations during welding (heating); Solid phase transformations during welding (cooling); Hardening and cold *****ing in steel welding; Heat treatments for steel welds; Metallurgical aspects of destructive and non-destructive weld tests
    Thanks a Lot
  11. thanks a lot too ...excelente material !!!
    Thank you!!!!
    Abdel fatah, thanks for sharing
  14. #11
    Fantastic and excellent sharing
    Thanks a Lot
  16. #12
    Dear Abdel,
    I tried the ifile site but it said the file had expired...could you pls upload again.Thanks
  1. Welding Books
    By vfq3481 in forum Mechanical Engineering
    Last Post: 02-06-2013, 07:50 PM
  2. Looking for Welding Books
    Last Post: 11-01-2012, 10:42 PM
  3. Wanted Welding Books
    By Manuwell in forum Mechanical Engineering
    Last Post: 10-28-2010, 06:40 PM
  4. Welding & metallurgy books
    By inconel in forum Materials Science &Corrosion
    Last Post: 07-29-2010, 01:35 PM
