Page 1 of 2 1 2 LastLast
Results 1 to 12 of 19
Thread: Hysys Air Stream
    Jan 2009
    somewhere on the earth
    Hysys Air Stream
    Dear engineers
    How can I define an Air Stream with 70% relative humidity and ambient temperature 45°C, in HYSYS?
    a
    You can use extension of hysys Saturate function.
    Enter air composition (N2, O2, Ar) then for each pound of the air (Enter) add 0.03 pound of water. This is an approximation, because the psychrometric chart does not extent RH & 45 C. Do you know the wet bulb temp?
    Jan 2009
    Thanx suchart
    but where could I set the relative humidity by using saturate extension? It saturates the air stream with enough amount of water not specifically 70% , I think.
    Dear mobek
    would you please describe the procedure, if the ambient temperature is 25°C ?
    I use the attached software to compute the wet bulb temperature,
    There is a file missing from the psychrocalc program you attached.
    Jan 2009
    sorry, try this one:
    Jan 2009
    sorry again, ambient temperature is 25°C
    Ok, now it makes sense! @25C & 70%RH you have to add 0.0135 lb of water to each lb of air.
    It's a straightforward thing, just use the psychrometric chart.
    By the way, do you have the hysys saturate extension file? if you do, pls share it with me.
    Jan 2009
    here you are, the hysys saturate extension
  14. #11
  16. #12
    thanks but this is an old version and doesn't work with hysys 2006. anyone has new ver.?
    Quote Originally Posted by motaleby View Post
  1. Article: Hysys Air Stream
    By motaleby in forum Home Articles
    Last Post: 06-18-2011, 07:04 PM
