Hi
I want to calculate the liquid flow through the opening formed by failure of a flange gasket between two bolts in a four bolt flange.
I can't find any specific method for this calculation - is there one ?
I've downloaded a couple of fluid flow texts, but flow through this type of slot doesn't seem to be covered.
I can see that either using the equivalent area of a circular orifice, or the equivalent diameter of the circumference of the square(ish) slot might work, but neither seem really appropriate.
Surely this is a commonly analysed failure ?
Help.
Geoff
