Thread: pad,tee reinforce
    Thumbs up pad,tee reinforce
    Dear friends
    i need a clear clarification about reinforce and unreinforce type of tee,
    how to select in field.
    Hi
    Reinforcement is needed when you make manual branch on pipelines , and the thickness is usually same of main line thickness with 2 times diameter of branch ,
    I mean if you have a pipe with thickness "t" and outside diameter "D" , and you need to make a branch with diameter "d" , thickness of reinforcement pad min must be t with diameter 2*d
    Also you can find more in ASME B31.3
    Thank you Very much
    Friend
    Quote Originally Posted by netspyking View Post
    Hi
    very accurate answer
