Advanced Machining Processes
stringent design requirements and difficult-to-machine materials such as tough super alloys, ceramics, and composites, have made traditional machining processes costly and obsolete. As a result, manufacturers and machine design engineers are turning to advance machining processes. These machining processes utilizes electrical, chemical, and optimal sources of energy to bind, form and cut materials. El-Hofy rigorously explains how each of these advanced machining process work, their machining system components, process variables and industrial applications, making this book the perfect guide for anyone designing, researching or converting to a more advance machining process.
Table of contents
Chapter 1: Material Removal Processes
Chapter 2: Mechanical Processes
Chapter 3: Chemical Processes
Chapter 4: Electrochemical Processes
Chapter 5: Thermal Processes
Chapter 6: Hybrid Electrochemical Processes
Chapter 7: Hybrid Thermal Processes
Chapter 8: Material Addition Processes
Topics
Non-Traditional Machine Tools and Operations
Classification of Non-Traditional Machining Processes
Jet Machines and Operations
Ultrasonic Machining Equipment and Operations
Chemical Machining
Electrochemical Machines and Operations
Electrochemical Grinding Machines and Operations
Electrical Discharge Machines and Operations
Electron Beam Machining Equipment and Operations
Laser Beam Machining Equipment and Operations
Plasma Arc Cutting Systems and Operations
Design for Abrasive Jet Machining
Nontraditional Machining Processes
Design for Chemical and Electrochemical Machining
Design for Thermal Machining
Mechanical Advanced Machining Processes (MAMP)
Ultrasonic Machining (USM)
Abrasive Water Jet Cutting (AWJC)
Thermoelectric Advanced Machining Processes
Electric Discharge Machining (EDM) and Wire EDM
Laser Beam Machining (LBM)
Electrochemical Advanced Machining Processes
Electrochemical Machining (ECM)
ECM Machine
Fine Finishing Processe
Abrasive Flow Machining (AFM)
Magnetic Abrasive Finishing (MAF)
Magnetic Float Polishing (MFP
