dear all
i want to share this nice book:
Heat Transfer in Process Engineering
By Eduardo Cao
Publisher: McGraw-Hill Professional
Number Of Pages: 576
Publication Date: 2009-08-12
ISBN-10 / ASIN: 0071624082
ISBN-13 / EAN: 9780071624084
Product Description:
Cutting-edge heat transfer principles and design applications
Apply advanced heat transfer concepts to your chemical, petrochemical, and refining equipment designs using the detailed information contained in this comprehensive volume. Filled with valuable graphs, tables, and charts, Heat Transfer in Process Engineering covers the latest analytical and empirical methods for use with current industry software. Select heat transfer equipment, make better use of design software, calculate heat transfer coefficients, troubleshoot your heat transfer process, and comply with design and construction standards.
Heat Transfer in Process Engineering allows you to:
Review heat transfer principles with a direct focus on process equipment design
Design, rate, and specify shell and tube, plate, and hairpin heat exchangers
Design, rate, and specify air coolers with plain or finned tubes
Design, rate, and specify different types of condensers with tube or shellside condensation for pure fluids or multicomponent mixtures
Understand the principles and correlations of boiling heat transfer, with their limits on and applications to different types of reboiler design
Apply correlations for fired heater ratings, for radiant and convective zones, and calculate fuel efficiency
Obtain a set of useful Excel worksheets for process heat transfer calculations
download link
please reply with your comments
